path: root/cpukit/include/linux (unfollow)
2022-03-25cpukit/include/linux: Change license to BSD-2Joel Sherrill4-12/+88
Updates #3053.
2022-03-10cpukit/: Scripted embedded brains header file clean upJoel Sherrill4-24/+0
Updates #4625.
2018-10-05Fix rbtree_postorder_for_each_entry_safe()Sebastian Huber1-2/+2
Use the non-standard typeof operator to avoid code generation errors with clang and use of uninitialized variable warnings with GCC and Coverity Scan. Update #3465.
2018-07-16linux: Add rbtree_postorder_for_each_entry_safe()Sebastian Huber1-0/+16
Update #3465.
2018-07-16linux: Simplify <linux/rbtree.h>Sebastian Huber1-45/+37
Remove the placeholder struct rb_node and use RBTree_Node directly via some C pre-processor defines to adjust the member names. Update #3465.
2018-07-16linux: Install <linux/rbtree.h>Sebastian Huber1-0/+133
This makes it possible to test this API. Update #3465.
2018-01-25Remove make preinstallChris Johns3-0/+680
