* | Fix rbtree_postorder_for_each_entry_safe() | Sebastian Huber | 2018-10-05 | 1 | -2/+2 |
| | | | | | | | | Use the non-standard typeof operator to avoid code generation errors with clang and use of uninitialized variable warnings with GCC and Coverity Scan. Update #3465. | ||||
* | linux: Add rbtree_postorder_for_each_entry_safe() | Sebastian Huber | 2018-07-16 | 1 | -0/+16 |
* | linux: Simplify <linux/rbtree.h> | Sebastian Huber | 2018-07-16 | 1 | -45/+37 |
| | | | | | | | Remove the placeholder struct rb_node and use RBTree_Node directly via some C pre-processor defines to adjust the member names. Update #3465. | ||||
* | linux: Install <linux/rbtree.h> | Sebastian Huber | 2018-07-16 | 1 | -0/+133 |
This makes it possible to test this API. Update #3465. |
