The fdt_get_max_phandle() function has some shortcomings. On one hand
it returns just a uint32_t which means to check for the "negative"
error code a caller has to explicitly check against the error code
(uint32_t)-1. In addition, the -1 is the only error code that can be
returned, so a caller cannot tell the difference between the various
failures.
Fix this by adding a new fdt_find_max_phandle() function that returns an
error code on failure and 0 on success, just like other APIs, and stores
the maximum phandle value in an output argument on success.
This also refactors fdt_get_max_phandle() to use the new function. Add a
note pointing out that the new fdt_find_max_phandle() function should be
preferred over fdt_get_max_phandle().
Signed-off-by: Thierry Reding <treding@nvidia.com>
Message-Id: <20190326153302.17109-1-thierry.reding@gmail.com>
[dwg: Reword for some inaccuracies in the commit message]
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This reverts commit 54ea41c22415cb0e283d22faf71202051c89400c.
The new fdt_generate_phandle() function can be used to generate a new,
unused phandle given a specific device tree blob. The implementation is
somewhat naive in that it simply walks the entire device tree to find
the highest phandle value and then returns a phandle value one higher
than that. A more clever implementation might try to find holes in the
current set of phandle values and fill them. But this implementation is
relatively simple and works reliably.
Also add a test that validates that phandles generated by this new API
are indeed unique.
Message-Id: <20190320151003.28941-1-thierry.reding@gmail.com>
Currently fdt_check_header() performs only some rudimentary checks, which
is not really what the name suggests. This strengthens fdt_check_header()
to check as much about the blob as is possible from the header alone: as
well as checking the magic number and version, it checks that the total
size is sane, and that all the sub-blocks within the blob lie within the
total size.
* This broadens the meaning of FDT_ERR_TRUNCATED to cover all sorts of
improperly terminated blocks as well as just a structure block without
FDT_END.
* This makes fdt_check_header() only succeed on "complete" blobs, not
in-progress sequential write blobs. The only reason this didn't fail
before was that this function used to be called by many RO functions
which are supposed to also work on incomplete SW blobs.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Simon Glass <sjg@chromium.org>
Prior the Mac OS 10.7, the function strnlen() was not available. This patch
implements strnlen() on Mac OS X versions that are below 10.7.
Signed-off-by: John Arbuckle <programmingkidx@gmail.com>
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
The default libfdt_env.h (for POSIXish userland builds) supports sparse
checking. It has a couple of helper macros, __force and __bitwise which
expand the relevant sparse attributes to enable checking for incorrect
or missing endian conversions.
Those are bad names: for one, leading underscores are supposed to be
reserved for the system libraries, and worse, some systems (including
RHEL7) do define those names already.
So change them to FDT_FORCE and FDT_BITWISE which are far less likely to
have collisions.
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
