There does not seem to be a strong reason to inline this function. Also
we are about to add some extra code to it which will increase its size.
Move it into fdt.c and use a simple declaration in libfdt.h
Signed-off-by: Simon Glass <sjg@chromium.org>
Message-Id: <20200220214557.176528-2-sjg@chromium.org>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Including libfdt.h in a C++ project fails during compilation with recent
version of GCC or Clang.
This simple example:
extern "C" {
#include <libfdt.h>
int main(void) { return 0; }
leads to the following errors with GCC 9.1.0:
/usr/include/libfdt.h: In function ‘void fdt32_st(void*, uint32_t)’:
/usr/include/libfdt.h:139:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
139 | uint8_t *bp = property;
| void*
/usr/include/libfdt.h: In function ‘void fdt64_st(void*, uint64_t)’:
/usr/include/libfdt.h:163:16: error: invalid conversion from ‘void*’ to ‘uint8_t*’ {aka ‘unsigned char*’} [-fpermissive]
163 | uint8_t *bp = property;
| void*
This commit adds an explicit cast to uint8_t* to fix this issue.
Signed-off-by: Luc Michel <luc.michel@greensocs.com>
Message-Id: <20190910104824.1321594-1-luc.michel@greensocs.com>
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
Searching for duplicate names scales O(n^2) with the number of names
added to a fdt, which can cause a noticable slowdown with larger device
trees and very slow CPU cores.
Add FDT_CREATE_FLAG_NO_NAME_DEDUP that allow the caller to trade fdt size
for speed in the creation process.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Message-Id: <20190509094122.834-4-npiggin@gmail.com>
There is a need to be able to specify some options when building an FDT
with the SW interface. This can be accomplished with minimal changes by
storing intermediate data in the fdt header itself, in fields that are
not otherwise needed during the creation process and can be set by
fdt_finish().
The fdt.magic field is already used exactly this way, as a state to
check with callers that the FDT has been created but not yet finished.
fdt.version and fdt.last_comp_version are used to make room for more
intermediate state. These are adjacent and unused during the building
process. last_comp_version is not yet used for intermediate state, but
it is zeroed and treated as used, so as to allow future growth easily.
A new interface, fdt_create_with_flags() is added, which takes 32-bit
flag value to control creation.
Message-Id: <20190509094122.834-3-npiggin@gmail.com>
It's now a trivial wrapper around fdt_find_max_phandle() so we might as
well inline it. We also remove it from the versioning linker script.
Theoretically, that's a breaking ABI change except that we haven't yet
released a version with it exposed in the shared object, so we can get
away with it.
The new fdt_generate_phandle() function can be used to generate a new,
unused phandle given a specific device tree blob. The implementation is
somewhat naive in that it simply walks the entire device tree to find
the highest phandle value and then returns a phandle value one higher
than that. A more clever implementation might try to find holes in the
current set of phandle values and fill them. But this implementation is
relatively simple and works reliably.
Also add a test that validates that phandles generated by this new API
are indeed unique.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Message-Id: <20190326153302.17109-3-thierry.reding@gmail.com>
The fdt_get_max_phandle() function has some shortcomings. On one hand
it returns just a uint32_t which means to check for the "negative"
error code a caller has to explicitly check against the error code
(uint32_t)-1. In addition, the -1 is the only error code that can be
returned, so a caller cannot tell the difference between the various
failures.
Fix this by adding a new fdt_find_max_phandle() function that returns an
error code on failure and 0 on success, just like other APIs, and stores
the maximum phandle value in an output argument on success.
This also refactors fdt_get_max_phandle() to use the new function. Add a
note pointing out that the new fdt_find_max_phandle() function should be
preferred over fdt_get_max_phandle().
Message-Id: <20190326153302.17109-1-thierry.reding@gmail.com>
[dwg: Reword for some inaccuracies in the commit message]
This function will append an address range property using parent node's
"#address-cells" and "#size-cells" properties.
It will be used in implementing kdump with kexec_file_load system call
at linux kernel for arm64 once it is merged into kernel tree.
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Message-Id: <20190327061552.17170-2-takahiro.akashi@linaro.org>
[dwg: Correct a SEGV error in the testcase]
This reverts commit 54ea41c22415cb0e283d22faf71202051c89400c.
are indeed unique.
Message-Id: <20190320151003.28941-1-thierry.reding@gmail.com>
The actual error is FDT_ERR_NOTFOUND, not FDT_ERR_NOT_FOUND.
Fixes: d29126c90acb0d70 ("libfdt: Add iterator over properties")
Fixes: 902d0f0953d0074b ("libfdt: Add a subnodes iterator macro")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The second parameter of fdt_getprop_by_offset() is called "offset", not
"ffset".
6dcb8ba4 "libfdt: Add helpers for accessing unaligned words" introduced
the fdt32_ld() and fdt64_ld() helpers for loading values from the FDT blob
which might not be naturally aligned. This matters for ARM, where
attempting a plain unaligned load will often cause an exception.
However, it seems the memcpy() we used here was surprisingly expensive,
making libfdt nearly 6x slower on at least some ARM platforms.
This patch takes an alternative approach, using a bunch of 1-byte loads
and shifts to implement the helpers.
According to the device tree specification, the default value for
#size-cells is 1, but fdt_size_cells() was returning 2 if this property
was not present.
This patch also makes fdt_address_cells() and fdt_size_cells() conform
to the behaviour documented in libfdt.h. The defaults are only returned
if fdt_getprop() returns -FDT_ERR_NOTFOUND, otherwise the actual error
is returned.
Signed-off-by: John Clarke <johnc@kirriwa.net>
Add internal fdt_cells() to avoid copy and paste. Test error cases and
default values. Fix typo in fdt_size_cells() documentation comment.
Signed-off-by: Sebastian Huber <sebastian.huber@embedded-brains.de>
This adds some helpers to load (32 or 64 bit) words from an fdt blob, even
if they're unaligned and we're on a platform that doesn't like plain
unaligned loads and stores. We then use the helpers in a number of places.
There are two purposes for this:
1) This makes libfdt more robust against a blob loaded at an unaligned
address. It's usually good practice to load a blob at a 64-bit
alignment, but it's nice to work even then.
2) Users can use these helpers to load integer values from within property
values. These can often be unaligned, even if the blob as a whole is
aligned, since some property encodings have integers and strings mixed
together without any alignment gaps.
Allow updating and creating properties, including special methods for
integers.
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
This new function implements a complete and thorough check of an fdt blob's
structure. Given a buffer containing an fdt, it should return 0 only if
the fdt within is structurally sound in all regards. It doesn't check
anything about the blob's contents (i.e. the actual values of the nodes and
properties), of course.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Simon Glass <sjg@chromium.org>
We have a couple of places within libfdt and its tests where we need to
find the size of the header, based on the version. Add a helper function
for it.
fdt_string() is used to retrieve strings from a DT blob's strings section.
It's rarely used directly, but is widely used internally.
However, it doesn't do any bounds checking, which means in the case of a
corrupted blob it could access bad memory, which libfdt is supposed to
avoid.
This write a safe alternative to fdt_string, fdt_get_string(). It checks
both that the given offset is within the string section and that the string
it points to is properly \0 terminated within the section. It also returns
the string's length as a convenience (since it needs to determine to do the
checks anyway).
fdt_string() is rewritten in terms of fdt_get_string() for compatibility.
Most of the diff here is actually testing infrastructure.
Currently fdt_check_header() performs only some rudimentary checks, which
is not really what the name suggests. This strengthens fdt_check_header()
to check as much about the blob as is possible from the header alone: as
well as checking the magic number and version, it checks that the total
size is sane, and that all the sub-blocks within the blob lie within the
total size.
* This broadens the meaning of FDT_ERR_TRUNCATED to cover all sorts of
improperly terminated blocks as well as just a structure block without
FDT_END.
* This makes fdt_check_header() only succeed on "complete" blobs, not
in-progress sequential write blobs. The only reason this didn't fail
before was that this function used to be called by many RO functions
which are supposed to also work on incomplete SW blobs.
This can be useful in particular in the kernel when booting on systems
with FDT-emitting firmware that is out of date. Releases of kexec-tools
on ppc64 prior to the end of 2014 are notable examples of such.
Signed-off-by: Nathan Whitehorn <nwhitehorn@freebsd.org>
[dwg: Some whitespace cleanups]
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
A comment in tests/stringlist.c refers to fdt_get_string(), which is not a
function that exists. From the content, it's supposed to be referring to
fdt_getprop_string().
A comment in libfdt.h has an extraneous space in a function name.
In some cases you need to add a property but the contents of it
are not known at creation time, merely the extend of it.
This method allows you to create a property of a given size (filled
with garbage) while a pointer to the property data will be provided.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[dwg: Corrected commit message]
The existing function to add a new property to a tree being built requires
that the entire contents of the new property be passed in. For some
applications it is more convenient to be able to add the property contents
later, perhaps by reading from a file. This avoids double-buffering of the
contents.
Add a new function to support this and adjust the existing fdt_property() to
use it.
There are a few places where libfdt.h cannot be used as is with swig:
- macros like fdt_totalsize() have to be defined as C declarations
- fdt_offset_ptr() and fdt_getprop_namelen() need special treatment due to
a TODO in the wrapper for fdt_getprop(). However they are not useful to
Python so can be removed
Add #ifdefs to work around these problem.
Device trees can contain empty (zero length) properties, which are often
used as boolean flags. These can already be created using fdt_setprop()
passing a length of zero and a pointer which is ignored. It is safe to
pass NULL, but that may not be obvious from the interface. To make it
clearer, add an fdt_setprop_empty() helper macro.
The device tree overlays are a good way to deal with user-modifyable
boards or boards with some kind of an expansion mechanism where we can
easily plug new board in (like the BBB, the Raspberry Pi or the CHIP).
Add a new function to merge overlays with a base device tree.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
So far, the BADPHANDLE error was only used for incorrect phandle values.
Extend that meaning to an improperly formatted phandle property.
Add a few new error codes to report the failure conditions we might
encounter in the overlay application code:
- FDT_ERR_BADOVERLAY, when an overlay cannot be parsed, even though its
structure is correct
- FDT_ERR_NOPHANDLES, when we ran out of available phandles and we
cannot use a new phandle without either using an invalid one (-1 or
0), or one already used.
Correct some typos discovered with the codespell utility.
Signed-off-by: Thomas Huth <thuth@redhat.com>
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Acked-by: Simon Glass <sjg@chromium.org>
[dwg: Remove unnecessary unsigned qualifier, correct a comment]
Add a function to retrieve a writeable property only by the first
characters of its name.
Add a function to retrieve the highest phandle in a given device tree.
Reviewed-by: Stefan Agner <stefan@agner.ch>
Implement a macro based on fdt_first_property_offset and
fdt_next_property_offset that provides a convenience to iterate over all
the properties of a given node.
[dwg: Removed a stray trailing blank line]
The fdt_for_each_subnode() iterator macro provided by this patch can be
used to iterate over a device tree node's subnodes. At each iteration a
loop variable will be set to the next subnode.
The code style here is slightly incorrect. Fix it.
There are a few lines that are over 80 columns. Fix these.
There are a few places with a space before a tab in this file. Fix them.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
