path: root/cpukit/include/drvmgr (unfollow)
2018-12-27drvmgr: Improve LP64 compatibilitySebastian Huber1-2/+2
2018-10-09leon, spwtdp: Initial driver commitJavier Jalle1-0/+4
2018-04-20drvmgr: Remove bsp_driver_level_hook()Sebastian Huber1-6/+0
Use RTEMS_SYSINIT_ITEM() instead. Update #2408.
2018-01-25Remove make preinstallChris Johns4-0/+1485
