path: root/cpukit/include/dev (follow)
* cpukit/spi: Allow driver specific ioctlChristian Mauderer2021-01-211-0/+7
| | | | This allows a SPI driver to add a hardware specific ioctl.
* dev/sc16is752: Fix declarationSebastian Huber2020-08-051-1/+1
* dev/sc16is752: Add set/get EFCR IO controlsSebastian Huber2019-06-141-0/+10
* dev/sc16is752: Add RS485 mode variantsSebastian Huber2019-06-141-1/+12
* doxygen: Put SPI Driver into group Device DriversAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* doxygen: Added I2C Driver to Device DriversAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* dev/sc16is752: Add GPIO access via ioctl.Christian Mauderer2018-02-121-0/+45
* spi: Use self-contained mutexSebastian Huber2018-02-021-2/+3
| | | | Update #2843.
* i2c: Use self-contained mutexSebastian Huber2018-02-021-2/+3
| | | | Update #2843.
* Remove make preinstallChris Johns2018-01-2512-0/+1897
