path: root/cpukit/include/dev/spi (follow)
* cpukit/include/dev: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* cpukit/spi: Allow driver specific ioctlChristian Mauderer2021-01-211-0/+7
| | | | This allows a SPI driver to add a hardware specific ioctl.
* doxygen: Put SPI Driver into group Device DriversAndreas Dachsberger2019-04-041-0/+2
| | | | Update #3706.
* spi: Use self-contained mutexSebastian Huber2018-02-021-2/+3
| | | | Update #2843.
* Remove make preinstallChris Johns2018-01-251-0/+216
