path: root/cpukit/include/dev/serial (follow)
* dev/sc16is752: Fix declarationSebastian Huber2020-08-051-1/+1
* dev/sc16is752: Add set/get EFCR IO controlsSebastian Huber2019-06-141-0/+10
* dev/sc16is752: Add RS485 mode variantsSebastian Huber2019-06-141-1/+12
* dev/sc16is752: Add GPIO access via ioctl.Christian Mauderer2018-02-121-0/+45
* Remove make preinstallChris Johns2018-01-251-0/+262
