path: root/cpukit/include/dev/i2c/fpga-i2c-slave.h (follow)
* cpukit/include/dev: Change license to BSD-2Joel Sherrill2022-03-251-3/+22
| | | | Updates #3053.
* Remove make preinstallChris Johns2018-01-251-0/+25
