path: root/cpukit/httpd (follow)
* Add missing initializers.Ralf Corsepius2008-09-071-1/+1
* Stop using old-style function definitions.Ralf Corsepius2008-09-0116-59/+59
* 2008-08-19 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-08-191-1/+1
| | | | * httpd/uemf.h: Add empty braces to macro.
* Add missing prototypes.Ralf Corsepius2008-07-309-53/+53
* 2007-12-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-062-5/+7
| | | | | | * httpd/Makefile.am, httpd/preinstall.am: rtems_webserver.h must be installed. It is the initialization interface for both GoAhead and Simple HTTPD.
* Regenerate.Ralf Corsepius2007-04-131-1/+1
* Use HAS_PTHREADS instead of LIBPOSIX.Ralf Corsepius2007-04-131-1/+1
* Regenerate.Ralf Corsepius2007-01-081-3/+3
* Regenerate.Ralf Corsepius2006-11-181-1/+1
* Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING).Ralf Corsepius2006-11-181-1/+1
* 2006-02-08 Thomas Rauscher <trauscher@loytec.com>Joel Sherrill2006-02-081-0/+5
| | | | | | | | PR 890/networking * httpd/webs.c: The webservers enters an infinite loop when a POST request with less data than indicated in the Content-Length header is received. It also consumes additional heap memory and a file descriptor for each invalid POST.
* Regenerate.Ralf Corsepius2006-01-141-1/+1
* Regenerate.Ralf Corsepius2006-01-121-0/+4
* Remove all-local.Ralf Corsepius2006-01-121-2/+0
* Regenerate.Ralf Corsepius2006-01-121-1/+1
* Regenerate.Ralf Corsepius2006-01-121-3/+3
* CleanupsRalf Corsepius2006-01-121-4/+0
* Regenerate.Ralf Corsepius2006-01-101-10/+10
* 2005-11-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-11-031-1/+0
| | | | * httpd/Makefile.am: Remove bogus noinst_LIBRARIES.
* Regenerate.Ralf Corsepius2005-06-011-0/+5
* Regenerate.Ralf Corsepius2005-05-241-5/+0
* socklen_t.Ralf Corsepius2005-05-101-2/+3
* Auto-generated update.Ralf Corsepius2005-02-191-1/+1
* Cosmetics.Ralf Corsepius2005-02-081-0/+5
* New.Ralf Corsepius2005-02-081-0/+69
* Split preinstallation rules in to separate files (preinstall.am).Ralf Corsepius2005-02-081-67/+3
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-071-1/+1
| | | | | | | | * httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-011-13/+5
| | | | | | | | | * automake/compile.am, httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* 2004-12-30 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-12-301-3/+14
| | | | | * httpd/rtems_webserver.h: Add doxygen preamble. Add C++ guards.
* 2004-12-30 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2004-12-301-1/+1
| | | | * httpd/Makefile.am: Remove -DOS="RTEMS".
* Install libhttpd.a.Ralf Corsepius2004-10-271-2/+13
* 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-201-1/+1
| | | | | * libnetworking/rtems_webserver/uemf.h: Use CHAR_BIT for BITSPERBYTE.
* Remove stray white spaces.Ralf Corsepius2004-04-1512-12/+0
* 2004-03-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-03-057-19/+24
| | | | | | | | | | * libnetworking/rtems_webserver/ejparse.c, libnetworking/rtems_webserver/emfdb.c, libnetworking/rtems_webserver/sock.c, libnetworking/rtems_webserver/socket.c, libnetworking/rtems_webserver/sym.c, libnetworking/rtems_webserver/webs.c, libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-091-1/+0
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-031-2/+4
| | | | | | | * libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-151-23/+19
| | | | | | | | | | | | | * Makefile.am: Remove wrapup. * pppd/Makefile.am: Build libpppd. Use automake-compilation rules. * rtems_servers/Makefile.am: Build libftpd. Use automake-compilation rules. * rtems_telnetd/Makefile.am: Build libtelnetd. Use automake-compilation rules. * rtems_webserver/Makefile.am: Build libhttpd. Use automake-compilation rules. * wrapup/Makefile.am: Remove (Unused).
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+4
| | | | | | | | * pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-4/+2
| | | | | | | * pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | * pppd/Makefile.am: Remove all-local: $(ARCH). * rtems_servers/Makefile.am: Remove all-local: $(ARCH). * rtems_telnetd/Makefile.am: Remove all-local: $(ARCH). * rtems_webserver/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-23/+60
| | | | | | | | | * Makefile.am: Reformat. Apply dirstamps to preinstallation. * pppd/Makefile.am: Ditto. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. rtems_servers/Makefile.am: Reflect having moved automake. rtems_telnetd/Makefile.am: Reflect having moved automake. rtems_webserver/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-251-5/+7
| | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * .cvsignore, Makefile.am, pppd/Makefile.am, rtems_servers/Makefile.am, rtems_telnetd/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-117-0/+3074
| | | | | | | * rtems_webserver/cgi.c, rtems_webserver/sockGen.c, rtems_webserver/umui.c, rtems_webserver/websSSL.c, rtems_webserver/websSSL.h, rtems_webserver/websda.c, rtems_webserver/websda.h: New files. Not included in previous commit.
* 2002-04-10 Mike Siers <mikes@poliac.com>Joel Sherrill2003-04-1137-309/+875
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems_webserver/NOTES, rtems_webserver/asp.c, rtems_webserver/balloc.c, rtems_webserver/default.c, rtems_webserver/ej.h, rtems_webserver/ejIntrn.h, rtems_webserver/ejlex.c, rtems_webserver/ejparse.c, rtems_webserver/emfdb.c, rtems_webserver/emfdb.h, rtems_webserver/form.c, rtems_webserver/h.c, rtems_webserver/handler.c, rtems_webserver/license.txt, rtems_webserver/md5.h, rtems_webserver/md5c.c, rtems_webserver/mime.c, rtems_webserver/misc.c, rtems_webserver/ringq.c, rtems_webserver/rom.c, rtems_webserver/security.c, rtems_webserver/sock.c, rtems_webserver/sym.c, rtems_webserver/uemf.c, rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h, rtems_webserver/url.c, rtems_webserver/value.c, rtems_webserver/wbase64.c, rtems_webserver/webcomp.c, rtems_webserver/webpage.c, rtems_webserver/webrom.c, rtems_webserver/webs.c, rtems_webserver/webs.h, rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h: Update to GoAhead Webserver 2.1.4. The following URL is the release notes from GoAhead. http://data.goahead.com/Software/Webserver/2.1.4/release.htm I have only done a minimal amount of testing (i.e. the network demo program works fine). Please try this out and let me know if it works. The patch needs to be applied on the c/src/libnetworking/rtems_webserver directory.
* 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-161-5/+1
| | | | | | | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * rtems_servers/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-041-2/+4
| | | | * pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-312-1/+2
| | | | | * rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed warnings.
* 2002-09-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-09-021-1/+1
| | | | * rtems_webserver/md5.h: Add missing newline.
* 2002-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-311-1/+1
| | | | * rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
