* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* httpd/rtems_webserver.h: Add doxygen preamble.
Add C++ guards.
* httpd/Makefile.am: Remove -DOS="RTEMS".
* libnetworking/rtems_webserver/uemf.h: Use CHAR_BIT for
BITSPERBYTE.
* libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* pppd/Makefile.am: Remove all-local: $(ARCH).
* rtems_servers/Makefile.am: Remove all-local: $(ARCH).
* rtems_telnetd/Makefile.am: Remove all-local: $(ARCH).
* rtems_webserver/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
pppd/Makefile.am: Reflect having moved automake.
rtems_servers/Makefile.am: Reflect having moved automake.
rtems_telnetd/Makefile.am: Reflect having moved automake.
rtems_webserver/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* rtems_webserver/cgi.c, rtems_webserver/sockGen.c,
rtems_webserver/umui.c, rtems_webserver/websSSL.c,
rtems_webserver/websSSL.h, rtems_webserver/websda.c,
rtems_webserver/websda.h: New files. Not included in previous commit.
* rtems_webserver/NOTES, rtems_webserver/asp.c,
rtems_webserver/balloc.c, rtems_webserver/default.c,
rtems_webserver/ej.h, rtems_webserver/ejIntrn.h,
rtems_webserver/ejlex.c, rtems_webserver/ejparse.c,
rtems_webserver/emfdb.c, rtems_webserver/emfdb.h,
rtems_webserver/form.c, rtems_webserver/h.c,
rtems_webserver/handler.c, rtems_webserver/license.txt,
rtems_webserver/md5.h, rtems_webserver/md5c.c,
rtems_webserver/mime.c, rtems_webserver/misc.c,
rtems_webserver/ringq.c, rtems_webserver/rom.c,
rtems_webserver/security.c, rtems_webserver/sock.c,
rtems_webserver/sym.c, rtems_webserver/uemf.c,
rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h,
rtems_webserver/url.c, rtems_webserver/value.c,
rtems_webserver/wbase64.c, rtems_webserver/webcomp.c,
rtems_webserver/webpage.c, rtems_webserver/webrom.c,
rtems_webserver/webs.c, rtems_webserver/webs.h,
rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h:
Update to GoAhead Webserver 2.1.4. The following URL is
the release notes from GoAhead.
http://data.goahead.com/Software/Webserver/2.1.4/release.htm
I have only done a minimal amount of testing (i.e. the network
demo program works fine). Please try this out and let me know
if it works. The patch needs to be applied on the
c/src/libnetworking/rtems_webserver directory.
* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* rtems_webserver/socket.c, rtems_webserver/uemf.h: Removed
warnings.
* rtems_webserver/md5.h: Add missing newline.
* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/misc.c: Per PR236 eliminate definition of strnlen().
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am,
netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am,
rtems_servers/Makefile.am, rtems_webserver/Makefile.am,
sys/Makefile.am, vm/Makefile.am:
* Makefile.am: Add handling of *.h files.
* configure.in: Remove include/Makefile.
* rtems_webserver/Makefile.am, rtems_webserver/base64.c,
rtems_webserver/base64.c: Renamed base64.c to wbase64.c.
* rtems_webserver/sock.c: Added file missed in merger.
* machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h,
rtems_webserver/webmain.c: machine/types.h should not have
included rtems.h. It is now including precisely the
least amount of low level, yet portable .h files to get
the basic RTEMS types defined. This rippled into other
files since rtems_bsdnet_internal.h used machine/types.h to include
rtems.h.
* kern/Makefile.am, lib/Makefile.am, libc/Makefile.am,
net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am,
pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* emfdb.c: Removed stray semi-colon. Reported on GoAhead
mailing lists by Jim Rudnicki <jdrudnicki@yahoo.com>
* Merged version 2.1 of GoAhead webserver. This update
was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>.
* NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c,
um.c, um.h: New files.
* wbase64.c: Removed.
* Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c,
form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c,
socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c,
webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
* rtems_webserver/license.txt: New file.
shuts down on error -- not exitting the system.
./bootstrap
in the previous commits.
to UnixWare (UW).
