path: root/cpukit/httpd/webmain.c (unfollow)
2002-08-312002-08-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* rtems_webserver/webmain.c: Commented out rootWeb to eliminate warning.
2002-08-142002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-2/+1
* rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
2000-09-222000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-0/+1
* machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
2000-09-012000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-18/+98
* Merged version 2.1 of GoAhead webserver. This update was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>. * NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c, um.c, um.h: New files. * wbase64.c: Removed. * Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c, form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c, socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c, webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
2000-06-30Patch from Chris Johns <cjohns@cybertec.com.au> so the web serverJoel Sherrill1-3/+5
shuts down on error -- not exitting the system.
1999-10-27Warnings removed. Still don't know what to do about the pragmaJoel Sherrill1-2/+9
pack warnings in uemf.h.
1999-10-27Patch from Emmanuel Raguet <raguet@crf.canon.fr> and Eric ValetteJoel Sherrill1-0/+410
<valette@crf.canon.fr> to add a port of the GoAhead web server (httpd) to the RTEMS build tree. They have successfully used this BSP on i386/pc386 and PowerPC/mcp750. Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on 26 Oct 1999 about this port and got verbal approval to include it in RTEMS distributions.
