path: root/cpukit/httpd/form.c (follow)
* 2002-04-10 Mike Siers <mikes@poliac.com>Joel Sherrill2003-04-111-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems_webserver/NOTES, rtems_webserver/asp.c, rtems_webserver/balloc.c, rtems_webserver/default.c, rtems_webserver/ej.h, rtems_webserver/ejIntrn.h, rtems_webserver/ejlex.c, rtems_webserver/ejparse.c, rtems_webserver/emfdb.c, rtems_webserver/emfdb.h, rtems_webserver/form.c, rtems_webserver/h.c, rtems_webserver/handler.c, rtems_webserver/license.txt, rtems_webserver/md5.h, rtems_webserver/md5c.c, rtems_webserver/mime.c, rtems_webserver/misc.c, rtems_webserver/ringq.c, rtems_webserver/rom.c, rtems_webserver/security.c, rtems_webserver/sock.c, rtems_webserver/sym.c, rtems_webserver/uemf.c, rtems_webserver/uemf.h, rtems_webserver/um.c, rtems_webserver/um.h, rtems_webserver/url.c, rtems_webserver/value.c, rtems_webserver/wbase64.c, rtems_webserver/webcomp.c, rtems_webserver/webpage.c, rtems_webserver/webrom.c, rtems_webserver/webs.c, rtems_webserver/webs.h, rtems_webserver/websuemf.c, rtems_webserver/wsIntrn.h: Update to GoAhead Webserver 2.1.4. The following URL is the release notes from GoAhead. http://data.goahead.com/Software/Webserver/2.1.4/release.htm I have only done a minimal amount of testing (i.e. the network demo program works fine). Please try this out and let me know if it works. The patch needs to be applied on the c/src/libnetworking/rtems_webserver directory.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-011-12/+15
| | | | | | | | | | | | * Merged version 2.1 of GoAhead webserver. This update was submitted by Antti P Miettinen <antti.p.miettinen@nokia.com>. * NOTES, base64.c, ejIntrn.h, emfdb.c, emfdb.h, md5.h, md5c.c, um.c, um.h: New files. * wbase64.c: Removed. * Makefile.am, asp.c, balloc.c, default.c, ej.h, ejlex.c, ejparse.c, form.c, h.c, handler.c, mime.c, misc.c, ringq.c, rom.c, security.c, socket.c, sym.c, uemf.c, uemf.h, url.c, value.c, webcomp.c, webmain.c, webpage.c, webrom.c, webs.c, webs.h, websuemf.c, wsIntrn.h: Modified.
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> and Eric ValetteJoel Sherrill1999-10-271-0/+163
<valette@crf.canon.fr> to add a port of the GoAhead web server (httpd) to the RTEMS build tree. They have successfully used this BSP on i386/pc386 and PowerPC/mcp750. Mark and Joel spoke with Nick Berliner <nickb@goahead.com> on 26 Oct 1999 about this port and got verbal approval to include it in RTEMS distributions.
