* | 2011-10-26 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-10-26 | 2 | -8/+7 |
| | | | | | * ftpd/ftpd.h, ftpd/ftpd.c: Moved buffer and stack size constants into header file. | ||||
* | 2011-10-26 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-10-26 | 1 | -3/+3 |
| | | | | | | * ftpd/ftpd.c: Increased data buffer size to 4096 bytes. Use RTEMS_MINIMUM_STACK_SIZE plus the data buffer size for worker thread stack size. | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -62/+31 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2011-06-24 Arnout Vandecappelle <arnout@mind.be> | Sebastian Huber | 2011-06-24 | 2 | -11/+91 |
| | | | | | | | Sebastien Bourdeauducq <sebastien@milkymist.org> PR 1724/cpukit * ftpd/ftpd.h, ftpd/ftpd.c: Added USER/PASS authentication. | ||||
* | 2011-06-07 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-06-07 | 1 | -6/+2 |
| | | | | | PR 1811/networking * ftpd/ftpd.c: Fixed reply format. | ||||
* | 2011-04-04 Sebastien Bourdeauducq <sebastien.bourdeauducq@gmail.com> | Joel Sherrill | 2011-04-04 | 1 | -18/+21 |
| | | | | | | PR 1722/networking * ftpd/ftpd.c: FTPD fails to parse correctly FTP commands relating to filenames with spaces in them. | ||||
* | 2011-02-23 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-23 | 1 | -0/+2 |
| | | | | * ftpd/ftpd.h: Add missing includes. | ||||
* | 2010-05-07 Arnout Vandecappelle <arnout@mind.be> | Sebastian Huber | 2010-05-07 | 1 | -0/+9 |
| | | | | | PR 1511/networking * ftpd/ftpd.c: Abort RETR for directories. | ||||
* | 2010-03-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-12 | 1 | -8/+8 |
| | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, httpd/asp.c, httpd/ejparse.c, httpd/emfdb.c, httpd/misc.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_format.c, libfs/src/dosfs/msdos_misc.c, libfs/src/nfsclient/src/nfs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/shell/shell.c, libmisc/shell/shell_makeargs.c, libmisc/uuid/parse.c, libnetworking/libc/gethostbydns.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_addr.c, libnetworking/libc/inet_network.c, libnetworking/libc/res_debug.c, libnetworking/libc/res_init.c, libnetworking/libc/res_query.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Readdress use of ctype methods per recommendation from D.J. Delorie on the newlib mailing list. We should pass an unsigned char into these methods. | ||||
* | 2010-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-11 | 1 | -8/+8 |
| | | | | | | | | | | | | * ftpd/ftpd.c, httpd/uemf.c, httpd/um.c, httpd/webs.c, httpd/websuemf.c, libblock/src/diskdevs.c, libmisc/capture/capture-cli.c, libmisc/monitor/mon-network.c, libmisc/shell/hexdump-odsyntax.c, libmisc/shell/main_ifconfig.c, libmisc/uuid/parse.c, libnetworking/lib/ftpfs.c, libnetworking/libc/gethostbyht.c, libnetworking/libc/getnetnamadr.c, libnetworking/libc/inet_network.c, libnetworking/rtems/rtems_mii_ioctl.c, score/src/objectgetnameasstring.c: Fix warnings for ctype methods. | ||||
* | 2009-03-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-03-12 | 1 | -0/+7 |
| | | | | * ftpd/ftpd.h: Add extern C. | ||||
* | Change SIX_MONTHS to time_t. | Ralf Corsepius | 2009-02-05 | 1 | -1/+1 |
* | Add __attribute__((unused)) to unused function args. | Ralf Corsepius | 2009-01-02 | 1 | -1/+1 |
* | Fix prototype. | Ralf Corsepius | 2008-08-29 | 1 | -1/+1 |
* | 2008-08-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-21 | 1 | -4/+4 |
| | | | | * ftpd/ftpd.c: Don't use annonymous unions. | ||||
* | Fix broken prototype. | Ralf Corsepius | 2008-08-01 | 1 | -1/+1 |
* | Add prototypes. | Ralf Corsepius | 2008-07-29 | 2 | -3/+3 |
* | 2007-08-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-28 | 1 | -6/+11 |
| | | | | | PR 1256/networking * ftpd/ftpd.c: Fix unaligned access. | ||||
* | 2007-05-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-08 | 1 | -0/+4 |
| | | | | * ftpd/ftpd.c: Add HAVE_CONFIG_H magic. | ||||
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | ||||
* | Regenerate | Ralf Corsepius | 2006-01-13 | 1 | -3/+5 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Regenerate. | Ralf Corsepius | 2005-06-01 | 1 | -0/+8 |
* | Regenerate. | Ralf Corsepius | 2005-05-24 | 1 | -8/+0 |
* | socklen_t. | Ralf Corsepius | 2005-05-10 | 1 | -2/+2 |
* | Auto-generated update. | Ralf Corsepius | 2005-02-19 | 1 | -1/+1 |
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 2 | -15/+28 |
| | | | | | | * ftpd/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * ftpd/preinstall.am: New (Generated from corresponding Makefile.am). | ||||
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 1 | -18/+1 |
| | | | | | | | * configure.ac: Add new header guard to cpuopts.h. * Makefile.am: Add libfs, libblock, ftpd header install rules. * libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove header install rules. | ||||
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-04 | 2 | -14/+24 |
| | | | | | | | | | | PR 756/rtems * ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from /c/src/libnetworking/ftpd) * ftpd/ftd.h: New header guards. * ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h. * configure.ac: Add ftpd/Makefile. * Makefile.am: Add ftpd. | ||||
* | New. | Ralf Corsepius | 2005-02-04 | 1 | -0/+2 |
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-03 | 1 | -1/+1 |
| | | | | * libnetworking/rtems_servers/ftpd.h: Warning fixes. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -1/+1 |
| | | | | | | | | * libchip/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -12/+3 |
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am: Remove build-variant support. | ||||
* | 2004-10-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-21 | 1 | -4/+4 |
| | | | | * libnetworking/rtems_servers/ftpd.c: Use POSIX fixed size types. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-09 | 1 | -1/+0 |
| | | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am. | ||||
* | 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-03 | 1 | -1/+3 |
| | | | | | | | * libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-15 | 1 | -24/+13 |
| | | | | | | | | | | | | | * Makefile.am: Remove wrapup. * pppd/Makefile.am: Build libpppd. Use automake-compilation rules. * rtems_servers/Makefile.am: Build libftpd. Use automake-compilation rules. * rtems_telnetd/Makefile.am: Build libtelnetd. Use automake-compilation rules. * rtems_webserver/Makefile.am: Build libhttpd. Use automake-compilation rules. * wrapup/Makefile.am: Remove (Unused). | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+4 |
| | | | | | | | | * pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -4/+2 |
| | | | | | | | * pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 1 | -1/+1 |
| | | | | | | | | * pppd/Makefile.am: Remove all-local: $(ARCH). * rtems_servers/Makefile.am: Remove all-local: $(ARCH). * rtems_telnetd/Makefile.am: Remove all-local: $(ARCH). * rtems_webserver/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+17 |
| | | | | | | | | | * Makefile.am: Reformat. Apply dirstamps to preinstallation. * pppd/Makefile.am: Ditto. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | | | | Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. rtems_servers/Makefile.am: Reflect having moved automake. rtems_telnetd/Makefile.am: Reflect having moved automake. rtems_webserver/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | ||||
* | 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-25 | 1 | -11/+13 |
| | | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * .cvsignore, Makefile.am, pppd/Makefile.am, rtems_servers/Makefile.am, rtems_telnetd/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac | ||||
* | 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-16 | 1 | -5/+1 |
| | | | | | | | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * rtems_servers/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. | ||||
* | 2002-09-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-09-07 | 1 | -0/+1 |
| | | | | | * pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve warnings. |
