path: root/cpukit/ftpd/preinstall.am (unfollow)
2018-01-25Remove make preinstallChris Johns1-25/+0
2014-08-29Regenerate all preinstall.am files.Chris Johns1-3/+3
With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash.
2014-08-28Regenerate all preinstall.am files.Joel Sherrill1-3/+3
Apparently, at some point automake output changed and these were not updated.
2007-01-08Regenerate.Ralf Corsepius1-1/+1
2006-11-18Regenerate.Ralf Corsepius1-1/+1
2006-01-13RegenerateRalf Corsepius1-3/+5
2005-06-01Regenerate.Ralf Corsepius1-0/+8
2005-05-24Regenerate.Ralf Corsepius1-8/+0
2005-02-19Auto-generated update.Ralf Corsepius1-1/+1
2005-02-082005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-4/+5
* ftpd/Makefile.am: Split preinstallation rules in to separate preinstall.am-files. * ftpd/preinstall.am: New (Generated from corresponding Makefile.am).
2005-02-08Cosmetics.Ralf Corsepius1-0/+8
2005-02-08New.Ralf Corsepius1-0/+14
