Add a function to retrieve the highest phandle in a given device tree.
Acked-by: Simon Glass <sjg@chromium.org>
Reviewed-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Because fdt_stringlist_contains() returns 1 or 0,
fdt_node_check_compatible() can just return the inverted value.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Using pointer arithmetic to generate a pointer outside a known object is,
technically, undefined behaviour in C. Unfortunately, we were using that
in fdt_offset_ptr() to detect overflows.
To fix this we need to do our bounds / overflow checking on the offsets
before constructing pointers from them.
Reported-by: David Binderman <dcb314@hotmail.com>
This patch catches the conditions where:
- 'splicepoint' is set to a point outside of [ fdt, fdt_totalsize(fdt) )
- 'newlen' is negative, or 'splicepoint' plus 'newlen' results in overflow
Either of these cases can be caused by math which overflows in calling
functions, or by sizes specified through dynamic means.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This allows BSPs to use this library.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
