Currently fdt_check_header() performs only some rudimentary checks, which
is not really what the name suggests. This strengthens fdt_check_header()
to check as much about the blob as is possible from the header alone: as
well as checking the magic number and version, it checks that the total
size is sane, and that all the sub-blocks within the blob lie within the
total size.
* This broadens the meaning of FDT_ERR_TRUNCATED to cover all sorts of
improperly terminated blocks as well as just a structure block without
FDT_END.
* This makes fdt_check_header() only succeed on "complete" blobs, not
in-progress sequential write blobs. The only reason this didn't fail
before was that this function used to be called by many RO functions
which are supposed to also work on incomplete SW blobs.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Simon Glass <sjg@chromium.org>
When creating a tree with the sequential write functions, certain things
have to be done in a certain order. You must create the memory reserve map
and only then can you create the actual tree structure.
The -FDT_ERR_BADSTATE return code is for if you try to do things out of
order. However, we weren't checking that very thoroughly, so it was
possible to generate a corrupted blob if, for example, you started calling
fdt_begin_node() etc. before calling fdt_finish_reservemap().
This makes the state checking more thorough disallow that.
Many of the libfdt entry points call some sort of sanity check function
before doing anything else. These need to do slightly different things for
the various classes of functions.
The read-only version is shared with the exported fdt_check_header(), which
limits us a bit in how we can improve it. For that reason split the two
functions apart (though the exported one just calls the ro one for now).
We also rename the functions for more consistency - they're all named
fdt_XX_probe_() where the XX indicates which class of functions they're
for. "probe" is a better "term" than the previous check, since they really
only do minimal validation.
This can be useful in particular in the kernel when booting on systems
with FDT-emitting firmware that is out of date. Releases of kexec-tools
on ppc64 prior to the end of 2014 are notable examples of such.
Signed-off-by: Nathan Whitehorn <nwhitehorn@freebsd.org>
[dwg: Some whitespace cleanups]
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
In some cases you need to add a property but the contents of it
are not known at creation time, merely the extend of it.
This method allows you to create a property of a given size (filled
with garbage) while a pointer to the property data will be provided.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[dwg: Corrected commit message]
These were noticed when synching with U-Boot's downstream tree.
Signed-off-by: Simon Glass <sjg@chromium.org>
The existing function to add a new property to a tree being built requires
that the entire contents of the new property be passed in. For some
applications it is more convenient to be able to add the property contents
later, perhaps by reading from a file. This avoids double-buffering of the
contents.
Add a new function to support this and adjust the existing fdt_property() to
use it.
The standard way of setting an empty property using libfdt is:
fdt_setprop(fdt, nodeoffset, propname, NULL, 0);
However, the implementation of this includes an unconditional:
memcpy(prop->data, NULL, 0);
Which although it will be a no-op (which is what we want) on many platforms
is technically undefined behaviour. Correct this, so that when passing
a 0 length, passing a NULL pointer as the value to fdt_setprop() is
definitely safe. This should quiet static checkers which complain about
this.
Some error values were missing from the table which meant that they could
not be translated by fdt_strerror().
Signed-off-by: Benjamin Fair <b-fair@ti.com>
If fdt_getprop() fails, negative error code should be returned.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
There's one FDT_ERR_BADOVERLAY too many in the fdt error table.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The BADPHANDLE error was missing a string, leading to an <unknown error>
string being returned if you were to call fdt_strerror.
Add a few new error codes to report the failure conditions we might
encounter in the overlay application code:
- FDT_ERR_BADOVERLAY, when an overlay cannot be parsed, even though its
structure is correct
- FDT_ERR_NOPHANDLES, when we ran out of available phandles and we
cannot use a new phandle without either using an invalid one (-1 or
0), or one already used.
The variable "err" is unneeded.
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Acked-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
[dwg: Remove unnecessary unsigned qualifier, correct a comment]
Add a function to retrieve the highest phandle in a given device tree.
Reviewed-by: Stefan Agner <stefan@agner.ch>
Because fdt_stringlist_contains() returns 1 or 0,
fdt_node_check_compatible() can just return the inverted value.
Using pointer arithmetic to generate a pointer outside a known object is,
technically, undefined behaviour in C. Unfortunately, we were using that
in fdt_offset_ptr() to detect overflows.
To fix this we need to do our bounds / overflow checking on the offsets
before constructing pointers from them.
Reported-by: David Binderman <dcb314@hotmail.com>
This patch catches the conditions where:
- 'splicepoint' is set to a point outside of [ fdt, fdt_totalsize(fdt) )
- 'newlen' is negative, or 'splicepoint' plus 'newlen' results in overflow
Either of these cases can be caused by math which overflows in calling
functions, or by sizes specified through dynamic means.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This allows BSPs to use this library.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
