The standard way of setting an empty property using libfdt is:
fdt_setprop(fdt, nodeoffset, propname, NULL, 0);
However, the implementation of this includes an unconditional:
memcpy(prop->data, NULL, 0);
Which although it will be a no-op (which is what we want) on many platforms
is technically undefined behaviour. Correct this, so that when passing
a 0 length, passing a NULL pointer as the value to fdt_setprop() is
definitely safe. This should quiet static checkers which complain about
this.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Some error values were missing from the table which meant that they could
not be translated by fdt_strerror().
Signed-off-by: Benjamin Fair <b-fair@ti.com>
If fdt_getprop() fails, negative error code should be returned.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
There's one FDT_ERR_BADOVERLAY too many in the fdt error table.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The BADPHANDLE error was missing a string, leading to an <unknown error>
string being returned if you were to call fdt_strerror.
Add a few new error codes to report the failure conditions we might
encounter in the overlay application code:
- FDT_ERR_BADOVERLAY, when an overlay cannot be parsed, even though its
structure is correct
- FDT_ERR_NOPHANDLES, when we ran out of available phandles and we
cannot use a new phandle without either using an invalid one (-1 or
0), or one already used.
The variable "err" is unneeded.
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Acked-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
[dwg: Remove unnecessary unsigned qualifier, correct a comment]
Add a function to retrieve the highest phandle in a given device tree.
Reviewed-by: Stefan Agner <stefan@agner.ch>
Because fdt_stringlist_contains() returns 1 or 0,
fdt_node_check_compatible() can just return the inverted value.
Using pointer arithmetic to generate a pointer outside a known object is,
technically, undefined behaviour in C. Unfortunately, we were using that
in fdt_offset_ptr() to detect overflows.
To fix this we need to do our bounds / overflow checking on the offsets
before constructing pointers from them.
Reported-by: David Binderman <dcb314@hotmail.com>
This patch catches the conditions where:
- 'splicepoint' is set to a point outside of [ fdt, fdt_totalsize(fdt) )
- 'newlen' is negative, or 'splicepoint' plus 'newlen' results in overflow
Either of these cases can be caused by math which overflows in calling
functions, or by sizes specified through dynamic means.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This allows BSPs to use this library.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
