With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_setprop_inplace_namelen_partial().
fdt_getprop_namelen() will only return negative error values in "proplen"
if the return value is NULL. So we can rely on "proplen" being positive
in our case and can safely cast it to an unsigned type.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Message-Id: <20201001164630.4980-5-andre.przywara@arm.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
These were noticed when synching with U-Boot's downstream tree.
Signed-off-by: Simon Glass <sjg@chromium.org>
Add a function to modify inplace only a portion of a property..
This is especially useful when the property is an array of values, and you
want to update one of them without changing the DT size.
Acked-by: Simon Glass <sjg@chromium.org>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
[dwg: Remove unnecessary unsigned qualifier, correct a comment]
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
