Signed-off-by: Patrick Oppenlander <patrick.oppenlander@gmail.com>
Message-Id: <20200618042117.131731-1-patrick.oppenlander@gmail.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This error indicates a logic bug in the code calling libfdt, so VALID_DTB
is not really the right check. Update it to use VALID_INPUT instead.
Signed-off-by: Simon Glass <sjg@chromium.org>
Suggested-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200302190255.51426-4-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
Searching for duplicate names scales O(n^2) with the number of names
added to a fdt, which can cause a noticable slowdown with larger device
trees and very slow CPU cores.
Add FDT_CREATE_FLAG_NO_NAME_DEDUP that allow the caller to trade fdt size
for speed in the creation process.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Message-Id: <20190509094122.834-4-npiggin@gmail.com>
There is a need to be able to specify some options when building an FDT
with the SW interface. This can be accomplished with minimal changes by
storing intermediate data in the fdt header itself, in fields that are
not otherwise needed during the creation process and can be set by
fdt_finish().
The fdt.magic field is already used exactly this way, as a state to
check with callers that the FDT has been created but not yet finished.
fdt.version and fdt.last_comp_version are used to make room for more
intermediate state. These are adjacent and unused during the building
process. last_comp_version is not yet used for intermediate state, but
it is zeroed and treated as used, so as to allow future growth easily.
A new interface, fdt_create_with_flags() is added, which takes 32-bit
flag value to control creation.
Message-Id: <20190509094122.834-3-npiggin@gmail.com>
If fdt_add_property or fdt_property_placeholder fail after allocating
a string for the name, they return without freeing that string. This
does not change the structure of the tree, but in very specific cases
it could lead to undesirable space consumption.
Fix this by rolling back the string allocation in this situation.
Message-Id: <20190509094122.834-2-npiggin@gmail.com>
At present fdt_create() will succeed if there is exactly enough space to
put in the fdt header. However, it sets the off_mem_rsvmap field, a few
bytes past that in order to align the memory reservation block.
Having block pointers pointing past the end of the fdt is pretty ugly, even
if it is just a transient state. Worse, if fdt_resize() is called at
exactly the wrong time, it can end up accessing data past the blob's
allocated space because of this.
So, correct fdt_create() to ensure that there is sufficient space for the
alignment padding as well as the plain header. For paranoia, also add a
check in fdt_resize() to make sure we don't copy data from outside the
blob's bounds.
At present this function appears to copy only the data before the struct
region and the data in the string region. It does not seem to copy the
struct region itself.
From the arguments of this function it seems that it should support fdt
and buf being different. This patch attempts to fix this problem.
When creating a tree with the sequential write functions, certain things
have to be done in a certain order. You must create the memory reserve map
and only then can you create the actual tree structure.
The -FDT_ERR_BADSTATE return code is for if you try to do things out of
order. However, we weren't checking that very thoroughly, so it was
possible to generate a corrupted blob if, for example, you started calling
fdt_begin_node() etc. before calling fdt_finish_reservemap().
This makes the state checking more thorough disallow that.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Simon Glass <sjg@chromium.org>
Many of the libfdt entry points call some sort of sanity check function
before doing anything else. These need to do slightly different things for
the various classes of functions.
The read-only version is shared with the exported fdt_check_header(), which
limits us a bit in how we can improve it. For that reason split the two
functions apart (though the exported one just calls the ro one for now).
We also rename the functions for more consistency - they're all named
fdt_XX_probe_() where the XX indicates which class of functions they're
for. "probe" is a better "term" than the previous check, since they really
only do minimal validation.
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
The existing function to add a new property to a tree being built requires
that the entire contents of the new property be passed in. For some
applications it is more convenient to be able to add the property contents
later, perhaps by reading from a file. This avoids double-buffering of the
contents.
Add a new function to support this and adjust the existing fdt_property() to
use it.
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
