Coverity gets a bit confused by loading fdt_size_dt_strings() and
using it in a memmove(). In fact this is safe because the callers
have verified this information (via FDT_RW_PROBE() in fdt_pack() or
construction in fdt_open_into()).
Passing in strings_size like we already do struct_size seems to get
Coverity to follow what's going on here.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Apparently the unchecked return value of the first fdt_next_tag() call in
fdt_add_subnode_namelen() is tripping Coverity Scan in some circumstances,
although it appears not to for the scan on our project itself.
This fdt_next_tag() should always return FDT_BEGIN_NODE, since otherwise
the fdt_subnode_offset_namelen() above would have returned BADOFFSET or
BADSTRUCTURE.
Still, add a check to shut Coverity up, gated by a can_assume() to avoid
bloat in small builds.
Reported-by: Ryan Long <ryan.long@oarcorp.com>
in fdt_open_into
Changes in v3:
- Remove noop version sets
- Set version correctly on loaded fdt in fdt_open_into
Fixes: f1879e1a50eb ("Add limited read-only support for older (V2 and V3) device tree to libfdt.")
Signed-off-by: Justin Covell <jujugoboom@gmail.com>
Message-Id: <20201229041749.2187-1-jujugoboom@gmail.com>
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_splice_().
Since we just established that oldlen is not negative, we can safely
cast it to an unsigned type.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Message-Id: <20200921165303.9115-8-andre.przywara@arm.com>
This condition uses bitwise OR but should be logical OR. Fix it.
Signed-off-by: Simon Glass <sjg@chromium.org>
Reported-by: kernel test robot <lkp@intel.com>
Message-Id: <20200615160033.87328-1-sjg@chromium.org>
libfdt: fix undefined behaviour in fdt_splice_()
Along the lines of commit d0b3ab0a0f46 ("libfdt: Fix undefined behaviour
in fdt_offset_ptr()"), fdt_splice_() similarly may not use pointer
arithmetic to do overflow checks. (The left side of the checks added by
d4c7c25c9ed1 ["libfdt: check for potential overrun in _fdt_splice()"]
doesn't really lend itself to similar replacement though.)
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Message-Id: <f2d09e81-7cb8-c5cc-9699-1ac05b0626ff@suse.com>
Add a way to remove this check and the reordering code, which is
unnecessary if the dtb is known to be correctly ordered.
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Message-Id: <20200220214557.176528-8-sjg@chromium.org>
Allow enabling FDT_ASSUME_LATEST to disable version checks.
Message-Id: <20200220214557.176528-7-sjg@chromium.org>
Allow enabling FDT_ASSUME_NO_ROLLBACK to disable rolling back after a
failed operation.
Message-Id: <20200220214557.176528-6-sjg@chromium.org>
Support ASSUME_VALID_DTB to disable some sanity checks
If we assume that the DTB itself is valid then we can skip some checks and
save code space. Add various conditions to handle this.
Message-Id: <20200220214557.176528-4-sjg@chromium.org>
Replace instances of dual GPLv2 or BSD license boilerplate with SPDX tags.
Signed-off-by: Rob Herring <robh@kernel.org>
Message-Id: <20190620211944.9378-3-robh@kernel.org>
If fdt_add_property or fdt_property_placeholder fail after allocating
a string for the name, they return without freeing that string. This
does not change the structure of the tree, but in very specific cases
it could lead to undesirable space consumption.
Fix this by rolling back the string allocation in this situation.
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
Message-Id: <20190509094122.834-2-npiggin@gmail.com>
Many of the libfdt entry points call some sort of sanity check function
before doing anything else. These need to do slightly different things for
the various classes of functions.
The read-only version is shared with the exported fdt_check_header(), which
limits us a bit in how we can improve it. For that reason split the two
functions apart (though the exported one just calls the ro one for now).
We also rename the functions for more consistency - they're all named
fdt_XX_probe_() where the XX indicates which class of functions they're
for. "probe" is a better "term" than the previous check, since they really
only do minimal validation.
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: Alexey Kardashevskiy <aik@ozlabs.ru>
In a lot of places libfdt uses a leading _ character to mark an identifier
as "internal" (not part of the published libfdt API). This is a bad idea,
because identifiers with a leading _ are generally reserved by the C
library or system. It's particularly dangerous for libfdt, because it's
designed to be able to be integrated into lots of different environments.
In some cases the leading _ has no purpose, so we simply drop it. In most
cases we move it to the end, as our new convention for marking internal
identifiers.
In some cases you need to add a property but the contents of it
are not known at creation time, merely the extend of it.
This method allows you to create a property of a given size (filled
with garbage) while a pointer to the property data will be provided.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[dwg: Corrected commit message]
These were noticed when synching with U-Boot's downstream tree.
The standard way of setting an empty property using libfdt is:
fdt_setprop(fdt, nodeoffset, propname, NULL, 0);
However, the implementation of this includes an unconditional:
memcpy(prop->data, NULL, 0);
Which although it will be a no-op (which is what we want) on many platforms
is technically undefined behaviour. Correct this, so that when passing
a 0 length, passing a NULL pointer as the value to fdt_setprop() is
definitely safe. This should quiet static checkers which complain about
this.
The variable "err" is unneeded.
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
This patch catches the conditions where:
- 'splicepoint' is set to a point outside of [ fdt, fdt_totalsize(fdt) )
- 'newlen' is negative, or 'splicepoint' plus 'newlen' results in overflow
Either of these cases can be caused by math which overflows in calling
functions, or by sizes specified through dynamic means.
Signed-off-by: Courtney Cavin <courtney.cavin@sonymobile.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Import from:
git://git.kernel.org/pub/scm/utils/dtc/dtc.git
Commit:
604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e
Date:
2015-09-29T09:09:08Z
