path: root/cpukit/dtc/libfdt/Makefile.am (unfollow)
2018-01-25Remove make preinstallChris Johns1-3/+0
2015-10-19libfdt: Merge into librtemscpuSebastian Huber1-1/+1
This allows BSPs to use this library.
2015-10-16libfdt: Initial importSebastian Huber1-0/+19
Import from: git://git.kernel.org/pub/scm/utils/dtc/dtc.git Commit: 604e61e081e3c6c8fa1a8189c71cb3908a5bbc1e Date: 2015-09-29T09:09:08Z
