path: root/cpukit/doxygen (follow)
* appl-config: Add missing "the"Sebastian Huber2021-04-301-11/+10
* appl-config: CONFIGURE_BSP_PREREQUISITE_DRIVERSSebastian Huber2021-04-301-2/+2
| | | | Replace copy and paste with a proper description.
* appl-config: Reformat option constraintsSebastian Huber2021-04-301-120/+209
| | | | | | If only one constraint is present, then use a single sentence, otherwise use a list for the constraints. Format the constraints so that the line length limit is maintained.
* CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZESebastian Huber2021-03-051-3/+11
| | | | | Ensure that CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE meets the task storage alignment requirement.
* Improve file header comment in generated filesSebastian Huber2021-01-251-3/+7
* config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZESebastian Huber2020-11-271-2/+4
| | | | | | Fix the documentation. Update #4181.
* config: CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZESebastian Huber2020-11-261-0/+63
| | | | | | | | | | In order to better support applications which use the new rtems_task_construct() directive add the CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If this option is specified, then the Classic API initialization task is constructed with rtems_task_construct(). Update #4181.
* doxygen: Use common syntax for groupsSebastian Huber2020-11-231-3/+4
* doxygen: Rename Internal to ImplementationSebastian Huber2020-11-231-2/+2
| | | | | | Use a top-level implementation group to gather implementation related files. The use of "Impl" is shorter and matches with the *impl.h file names.
* Improve automatically generated warningSebastian Huber2020-11-121-5/+4
* doxygen: Add "Generated from ..." commentsSebastian Huber2020-10-081-4/+339
| | | | | | Improve file header comment. Update #3994.
* doxygen: Fix use of getchark() and rtems_putc()Sebastian Huber2020-09-281-6/+6
* doxygen: Wrap long linesSebastian Huber2020-09-181-10/+20
* validation: Add general purpose test suiteSebastian Huber2020-09-171-0/+6
| | | | | | | | | Add a general purpose test suite for validation tests. This is the first test suite generated from a specification item in the rtems-central repository. Update #3959.
* doxygen: Move top-level group definitionsSebastian Huber2020-09-171-0/+44
| | | | Update #3959.
* rtems: Add rtems_task_construct()Sebastian Huber2020-09-171-0/+22
| | | | | | | | | | | | | | | | | In contrast to rtems_task_create() this function constructs a task with a user-provided task storage area. The new directive uses a configuration structure instead of individual parameters. Add RTEMS_TASK_STORAGE_SIZE() to calculate the recommended size of a task storage area based on the task attributes and the size dedicated to the task stack and thread-local storage. This macro may allow future extensions without breaking the API. Add application configuration option CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE to adjust RTEMS Workspace size estimate. Update #3959.
* CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZESebastian Huber2020-09-171-0/+37
| | | | | | | | | | | Add this application configuration option. This configuration option can be used to reserve space for the dynamic linking of modules with thread-local storage objects. Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a thread-local storage size. Update #4074.
* Document application configuration optionsSebastian Huber2020-08-071-0/+4191
Add a new directory for Doxygen-specific documentation content. Add a Doxygen only header file containing documentation of the application configuration options. The header file is generated from specification items. Close #3994.
