This may help to avoid character loss.
Ensures that the FCR values are used.
This work was performed as a GCI 2018 task.
Avoid division by zero and instead disable rx/tx in case of a zero baud
value. Problem identified by Coverity Scan.
The field names for the registers generated a name collision (MSR_RI on
the power pc). This patch adds a SC16IS752_ prefix for all field names.
Closes #3501.
This add ths following ioctl calls to the sc16is752 driver:
- TIOCMGET
- TIOCMSET
- TIOCMBIS
- TIOCMBIC
Escalate a failed installation of the interrupts to the next higher
level.
Update #2843.
Update #2843.
Setting the PIRQ to 0 before reading the data produces a short clock pulse.
Moving the write to after reading the data fixes the issue.
Close #3173
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Close #3163.
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it
to calculate the program timeout in ticks. Check program done condition
after the timeout check to account for pre-emptions.
Update #3162.
Update #3161.
Update #2133.
Update #3082.
ADS1114 and ADS1115
Closes #3101.
This is a generic driver for use with Xilinx AXI I2C controller IP.
Closes #3100.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
Update #2897.
Update #2841.
User API is compatible to Linux userspace API. New test libtests/spi01.
Update #2776.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
Coverity ID 1255520. fd was not closed on error path.
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of an I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported (I2C_M_NOSTART).
