* | Update company name | Sebastian Huber | 2023-05-20 | 1 | -1/+1 |
| | | | | | The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | dev/sc16is752: Reduce RX FIFO trigger level | Sebastian Huber | 2019-08-26 | 1 | -2/+2 |
| | | | | This may help to avoid character loss. | ||||
* | dev/sc16is752: Set TLS to zero | Sebastian Huber | 2019-08-26 | 1 | -0/+14 |
| | | | | Ensures that the FCR values are used. | ||||
* | dev/sc16is752: Do FIFO reset separately | Sebastian Huber | 2019-08-26 | 1 | -0/+5 |
* | dev/sc16is752: Enable enhanced func early | Sebastian Huber | 2019-08-26 | 1 | -1/+2 |
* | dev/sc16is752: Write to right register | Sebastian Huber | 2019-08-26 | 1 | -1/+1 |
* | dev/sc16is752: Add set/get EFCR IO controls | Sebastian Huber | 2019-06-14 | 1 | -0/+6 |
* | dev/sc16is752: Add RS485 mode variants | Sebastian Huber | 2019-06-14 | 1 | -4/+16 |
* | dev/sc16is752: Fix parity generation. | Christian Mauderer | 2019-02-27 | 1 | -0/+1 |
* | dev/sc16is752: Deal with a baud of zero | Sebastian Huber | 2018-10-05 | 1 | -8/+13 |
| | | | | | Avoid division by zero and instead disable rx/tx in case of a zero baud value. Problem identified by Coverity Scan. | ||||
* | dev/sc16is752: Add name space for field names. | Christian Mauderer | 2018-08-15 | 1 | -41/+44 |
| | | | | | | | The field names for the registers generated a name collision (MSR_RI on the power pc). This patch adds a SC16IS752_ prefix for all field names. Closes #3501. | ||||
* | dev/sc16is752: Add ioctl calls for modem controll. | Christian Mauderer | 2018-05-14 | 1 | -0/+79 |
| | | | | | | | | This add ths following ioctl calls to the sc16is752 driver: - TIOCMGET - TIOCMSET - TIOCMBIS - TIOCMBIC | ||||
* | dev/sc16is752: Check return values. | Christian Mauderer | 2018-02-12 | 1 | -4/+6 |
| | | | | | Escalate a failed installation of the interrupts to the next higher level. | ||||
* | dev/sc16is752: Add GPIO access via ioctl. | Christian Mauderer | 2018-02-12 | 1 | -0/+20 |
* | bsps: Fix baud settings | Sebastian Huber | 2017-04-03 | 1 | -1/+1 |
| | | | | Update #2897. | ||||
* | dev: Add NXP SC16IS752 serial device driver | Alexander Krutwig | 2016-12-16 | 1 | -0/+330 |
Update #2841. |
