2017-10-02 | i2c: Add temperature sensor LM75A driver | Sebastian Huber | 1 | -0/+198 | |
Close #3163. | |||||
2017-10-02 | i2c: Fix EEPROM driver program timeout handling | Sebastian Huber | 1 | -4/+13 | |
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it to calculate the program timeout in ticks. Check program done condition after the timeout check to account for pre-emptions. Update #3162. | |||||
2017-10-02 | i2c: Send MSB of address first for EEPROMs | Sebastian Huber | 1 | -12/+21 | |
Update #3161. | |||||
2017-08-25 | Include missing <string.h> | Sebastian Huber | 1 | -0/+1 | |
Update #2133. | |||||
2017-08-22 | dev/i2c: Fix integer type | Sebastian Huber | 1 | -1/+1 | |
Update #3082. | |||||
2017-08-20 | dev/i2c: Add I2C device support for FPGA Slave, LM25066A, TMP112, ADS1113, ↵ | Chris Johns | 4 | -0/+976 | |
ADS1114 and ADS1115 Closes #3101. | |||||
2017-08-16 | dev/i2c: Add Xilinx AXI I2C driver. | Chris Johns | 1 | -0/+943 | |
This is a generic driver for use with Xilinx AXI I2C controller IP. Closes #3100. | |||||
2017-07-14 | posix/mmap: Add support for file handler and MAP_ANON | Kevin Kirspel | 2 | -0/+2 | |
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r. Updated each file handler object to support the default mmap handler. Updated mmap() to call the mmap handler for MAP_SHARED. Added a mmap file handler for shm Added support for MAP_ANON in mmap(). Updates #2859 | |||||
2015-07-23 | i2c: Fix return status of i2c dev read/write | Sebastian Huber | 1 | -6/+10 | |
2015-01-27 | IMFS: Replace node union with individual struct | Sebastian Huber | 2 | -18/+14 | |
This reduces the average node size. Add and use IMFS_GENERIC_INITIALIZER(). | |||||
2014-11-26 | i2c: Do not close file descriptor 0 if open fails | Sebastian Huber | 1 | -7/+6 | |
2014-11-26 | i2c: Avoid undefined right shift operation | Sebastian Huber | 1 | -5/+8 | |
2014-11-25 | cpukit/dev/i2c/i2c-dev.c: Fix leak on error path | Joel Sherrill | 1 | -2/+1 | |
Coverity ID 1255520. fd was not closed on error path. | |||||
2014-11-24 | i2c: Fix endian issue | Sebastian Huber | 1 | -9/+14 | |
2014-11-20 | Add NXP PCA9548A 8-channel switch I2C driver | Sebastian Huber | 1 | -0/+99 | |
2014-11-20 | Add NXP PCA9535 16-bit GPIO I2C driver | Sebastian Huber | 1 | -0/+149 | |
2014-11-20 | Add generic EEPROM I2C device driver | Sebastian Huber | 1 | -0/+260 | |
2014-11-20 | Add I2C driver framework | Sebastian Huber | 2 | -0/+642 | |
This I2C driver framework has some major differences compared to libi2c. * It is compatible to the Linux I2C user-space API. * It uses generic IMFS nodes and thus reduces the levels of indirection. * The drivers don't have to mess around with minor numbers to get their state information. * No arbitrary bus controller model is assumed. The main task of an I2C bus controller driver is to process I2C messages. How this is done is private to the driver. * Scatter/gather operations are supported (I2C_M_NOSTART). |
