#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
Coverity ID 1255520. fd was not closed on error path.
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of an I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported (I2C_M_NOSTART).
