path: root/cpukit/dev/Makefile.am (unfollow)
2018-10-09build: Merge dev/Makefile.amSebastian Huber1-23/+0
2018-01-25Remove make preinstallChris Johns1-34/+0
2017-10-02i2c: Add temperature sensor LM75A driverSebastian Huber1-0/+2
Close #3163.
2017-08-20dev/i2c: Add I2C device support for FPGA Slave, LM25066A, TMP112, ADS1113, ↵Chris Johns1-0/+8
ADS1114 and ADS1115 Closes #3101.
2017-08-16dev/i2c: Add Xilinx AXI I2C driver.Chris Johns1-0/+2
This is a generic driver for use with Xilinx AXI I2C controller IP. Closes #3100.
2016-12-16dev: Add NXP SC16IS752 serial device driverAlexander Krutwig1-0/+7
Update #2841.
2016-09-16Add SPI bus frameworkAlexander Krutwig1-0/+9
User API is compatible to Linux userspace API. New test libtests/spi01. Update #2776.
2014-11-20Add NXP PCA9548A 8-channel switch I2C driverSebastian Huber1-0/+2
2014-11-20Add NXP PCA9535 16-bit GPIO I2C driverSebastian Huber1-0/+2
2014-11-20Add generic EEPROM I2C device driverSebastian Huber1-0/+2
2014-11-20Add I2C driver frameworkSebastian Huber1-0/+11
This I2C driver framework has some major differences compared to libi2c. * It is compatible to the Linux I2C user-space API. * It uses generic IMFS nodes and thus reduces the levels of indirection. * The drivers don't have to mess around with minor numbers to get their state information. * No arbitrary bus controller model is assumed. The main task of an I2C bus controller driver is to process I2C messages. How this is done is private to the driver. * Scatter/gather operations are supported (I2C_M_NOSTART).
2014-11-20Add RTEMS port of Linux I2C user-space APISebastian Huber1-0/+12
