* configure.ac: Remove unused AM_CONDITIONAL([NEED_SYS_CDEFS_H]).
Remove unused AM_CONDITIONAL([NEED_SYS_QUEUE_H]).
* libcsupport/src/sleep_noposix.c: Remove.
* libcsupport/Makefile.am: Reflect changes above.
* posix/src/sleep.c, posix/src/usleep.c: Remove.
* posix/Makefile.am: Reflect changes above.
* configure.ac: Error out if libc doesn't provide sleep, usleep.
* libcsupport/src/creat.c: Remove.
* configure.ac: Error out if libc doesn't provide creat.
* libcsupport/src/opendir.c, libcsupport/src/closedir.c,
libcsupport/src/readdir.c, libcsupport/src/rewinddir.c,
libcsupport/src/scandir.c, libcsupport/src/seekdir.c,
libcsupport/src/telldir.c: Remove.
* libcsuppport/Makefile.am: Reflect changes above.
opendir, closedir, readdir, rewinddir, scandir, seekdir,
telldir.
* configure.ac: Remove extraneous spaces.
* configure.ac, posix/src/signal_2.c: sighandler_t is defined
conditionally in some versions of newlib and unconditionally in
others. Make sure we always compile.
* configure.ac: pthread_attr* functions are in <pthread.h>, not in
<pthreads.h>.
* Makefile.am, configure.ac: Revert accident commit adding libdbm to
build.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* configure.ac: Add checks for pthread_attr_getguardsize,
pthread_attr_setguardsize, pthread_attr_setstack,
pthread_attr_getstack.
* configure.ac: Apply RTEMS_CHECK_FUNC for set/get*id family of
functions. Extend set/get*id family of checks.
* configure.ac: Add checks for [get|set][e][uid,gid] family of
functions.
* configure.ac, score/include/rtems/score/percpu.h: Add
__RTEMS_SIZEOF_VOID_P__ to cpuopts.h so percpu.h has this information
available during build and after installation.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
PR 1561/cpukit
* configure.ac, score/cpu/Makefile.am: Merge SPARC64 port.
* include/rtems/tar.h, libcsupport/include/tar.h: Remove.
* configure.ac: Require toolchain to provide tar.h.
* libfs/src/imfs/imfs_load_tar.c, libmisc/untar/untar.h:
Use <tar.h> instead of <rtems/tar.h>.
* configure.ac: Remove c4x.
* Makefile.am, configure.ac: Remove support for shttpd.
* aclocal/enable-shttpd.m4: Remove.
* Makefile.am, configure.ac: Remove support for httpd (GoAhead).
* aclocal/enable-httpd.m4: Remove.
* libfs/src/nfsclient/src/dirutils.c: Add PRIomode_t, PRIdoff_t.
* configure.ac: Add AC_CHECK_SIZEOF(mode_t), AC_CHECK_SIZEOF(off_t).
* configure.ac: Add missing "&&".
* configure.ac: Add RTEMS_ENABLE_SHTTPD, RTEMS_ENABLE_HTTPD.
Introduce AM_CONDITIONALS LIBHTTPD, LIBSHTTPD.
* configure.ac: Check for sched.h.
* configure.ac: Check for WORD_BIT, LONG_BIT.
* configure.ac: Check for flockfile, funlockfile, ftrylockfile.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Changed the configuration of statistics granularity to use just one
define.
* configure.ac: Add mghttpd/Makefile.
* aclocal/gcc-sanity.m4: New.
* configure.ac: Add RTEMS_CHECK_GCC_SANITY.
* configure.ac: Remove -fasm.
* configure.ac: Remove UNIX AM_CONDITIONAL.
* configure.ac: Remove RTEMS_UNIX, RTEMS_UNIXLIB.
* configure.ac, score/src/threadqenqueuepriority.c: Add
RTEMS_DO_NOT_UNROLL_THREADQ_ENQUEUE_PRIORITY to give user ability to
disable the loop in _Thread_queue_Enqueue_priority from being
unrolled. This reduces code size and makes coverage analysis easier.
* configure.ac: Disable LIBSHELL for unix targets.
* configure.ac: Require <errno.h>. Cleanup comments.
Remove check for <sys/errno.h>.
* configure.ac: Require stdint.h.
* configure.ac: Check for functions in newlib.
* configure.ac, librpc/src/xdr/xdr_float.c, score/cpu/Makefile.am: Add
Lattice Mico32 support.
