path: root/cpukit/automake (follow)
* 2002-07-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-311-1/+0
| | | | | | * aclocal/canonicalize-tools.m4: Remove LD. * automake/lib.am: Remove LD. * Makefile.am: Put preinstall-stamp into CLEANFILES.
* 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-261-5/+5
| | | | * automake/compile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-2/+2
| | | | | * automake/lib.am: Use project_libdir instead of $(PROJECT_RELEASE)/lib.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-221-27/+2
| | | | | | | | | | | * aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE. Add project_libdir, libdir. New GCC_SPECS. Various cleanups. * aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE. Add project_libdir, libdir. New GCC_SPECS. Various cleanups. * aclocal/rtems-top.m4: New PROJECT_ROOT handling. * automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK, references to bsp_specs. Use project_libdir instead of $(PROJECT_RELEASE)/lib.
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-051-1/+6
| | | | | | | | | | | * automake/multilib.am: Add install-multi. * aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting version.m4. Add --with-project-root. Reflect --with-project-root to setting up PROJECT_ROOT. * aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK). * aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir. * aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-271-53/+6
| | | | | | | | | * aclocal/prog-ccas.m4: New. * aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP. RTEMS_GCC_PRINT * aclocal/check-multiprocessing.m4: Fix typo. * automake/compile.am: Remove CXX support. Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
* Copied over from the automake/Ralf Corsepius2002-06-155-0/+385
