Update #3254.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* automake/compile.am: Remove -Werror=...
* automake/compile.am: (Temporarily) Add -Werror=overflow,
-Werror=pointer-to-int-cast, -Werror=int-to-pointer-cast.
* automake/compile.am: Remove depend: (Redundant).
* automake/compile.am: Remove RTEMS_CPPFLAGS.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V.
Remove CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE.
Cleanup comments.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
* automake/compile.am: Cleanup comments. Remove ASFLAGS.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* automake/compile.am: Remove RTEMS_CFLAGS_*_V.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* automake/local.am: Remove depend-am.
* automake/subdirs.am: Remove depend-recursive.
* Makefile.am: Remove AUTOMAKE_FILES.
* automake/compile.am: Replace contents with contents of
automake/amcompile.am.
* automake/amcompile.am, automake/lib.am: Remove.
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* automake/amcompile.am: New.
* configure.ac: Add subdir-objects, AM_PROG_CC_C_O.
* automake/compile.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* aclocal/lead-dot.m4: Remove (Use the version in automake-1.8).
* automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR).
* aclocal/env-rtemscpu.m4: Reflect new definition of project_lib.
* Makefile.am: Remove BUILT_SOURCES.
* automake/compile.am: Add $(ARCH)/$(dirstamp) rules.
* wrapup/Makefile.am: Reflect $(dirstamp) changes.
* automake/local.am: Remove "debug".
PR 321:
* aclocal/env-rtemscpu.m4: Remove support for profile-variant.
* automake/compile.am: Ditto.
* automake/local.am: Ditto.
* automake/compile.am: Remove LIBSUFFIX_VA (unused).
* automake/local.am: Remove distclean-local.
Remove PROJECT_TOOLS.
* automake/compile.am: Remove CLEAN_DEPEND (Unused).
Remove CLOBBER_DEPEND (Unused).
* automake/compile.am: Remove $(RTEMS_BSP_CFLAGS).
* automake/compile.am: Rework *FLAGS, AM_*FLAGS handling.
* automake/multilib.am: Don't include @RTEMS_BSP@.cfg.
* automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Hard-code RTEMS_CFLAGS_PROFILE = -pg
* aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4.
Remove GCCSED.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V.
* automake/compile.am: Remove CFLAGS_DEBUG_OPTIMIZE_V (Unused).
* aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS.
* automake/compile.am: Acknowledge configuration-time CFLAGS.
Remove CFLAGS_DEFAULT.
* aclocal/canonicalize-tools.m4: Remove LD.
* automake/lib.am: Remove LD.
* Makefile.am: Put preinstall-stamp into CLEANFILES.
* automake/compile.am: Use .$(OBJEXT) instead of .o.
* automake/lib.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
* automake/multilib.am: Add install-multi.
* aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting
version.m4.
Add --with-project-root.
Reflect --with-project-root to setting up PROJECT_ROOT.
* aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK).
* aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir.
* aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
