* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 2 | -0/+18 |
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 2 | -0/+20 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -12/+13 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | fixed typo | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 2 | -8/+36 |
| | | | | making sure every True/False reference was fully qualified. | ||||
* | Added RTEMS boolean constants. | Joel Sherrill | 1997-06-03 | 1 | -0/+3 |
* | Added Pending_Events and lined up other event constants | Joel Sherrill | 1997-06-03 | 1 | -33/+34 |
* | added more constants and fixed numer | Joel Sherrill | 1997-06-03 | 2 | -24/+64 |
* | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 1997-06-03 | 2 | -5/+74 |
* | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 1997-06-03 | 2 | -16/+6 |
| | | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | ||||
* | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1997-06-02 | 1 | -8/+23 |
* | added new files from test area. | Joel Sherrill | 1997-06-02 | 2 | -0/+3372 |
This code has successfully been used to run sp01. |
