* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -1/+7 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -3/+10 |
| | | | | | * Makefile.am: Move include_adadir into RTEMS_ADA condional block. Add CLEANFILES. Add PREINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 2 | -4/+8 |
| | | | | * Makefile.am: Use include_ada_HEADERS. | ||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -10/+30 |
| | | | | | * Makefile.am: Preinstall adainclude_HEADERS. Add $(dirstamp) to preinstallation rules. | ||||
* | 2003-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-11-25 | 2 | -0/+29 |
| | | | | | PR 528/rtems_misc * rtems.ads: Add task variables to Ada binding. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 5 | -4/+9 |
| | | | | | * rtems-multiprocessing.adb, rtems-multiprocessing.ads, rtems.adb, rtems.ads: URL for license changed. | ||||
* | Cleanup | Ralf Corsepius | 2003-07-08 | 1 | -12/+0 |
* | 2003-07-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-07-08 | 2 | -1/+6 |
| | | | | | PR 418/ada * rtems.adb: Add missing all keyword to derefence pointer. | ||||
* | 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-07-08 | 3 | -29/+9 |
| | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2003-02-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-02-03 | 3 | -4/+11 |
| | | | | | | PR 338/filesystem * rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change). | ||||
* | 2003-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-03 | 2 | -12/+21 |
| | | | | | * rtems.ads: Corrected Configuration_Table record definition to match current RTEMS source. sp01 now runs. | ||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 |
| | | | | * configure.ac: Fix package name. | ||||
* | 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-29 | 3 | -1/+9 |
| | | | | | * configure.ac: Remove AC_ENABLE_MULTILIB. * Makefile.am: Add CVS-Id. | ||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-30 | 2 | -11/+6 |
| | | | | * rtems.adb (IO_Initialize): Make this match the C prototype. | ||||
* | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-27 | 2 | -2/+5 |
| | | | | * rtems.ads: Corrected binding for Io_Initialize. | ||||
* | 2001-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-23 | 4 | -0/+68 |
| | | | | | | * configure.ac: New. * Makefile.am: New. * .cvsignore: New. | ||||
* | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-01 | 5 | -294/+274 |
| | | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When. | ||||
* | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-01 | 1 | -0/+4 |
| | | | | * ChangeLog: New file. | ||||
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 2 | -0/+18 |
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 2 | -0/+20 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -12/+13 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | fixed typo | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 2 | -64/+9 |
| | | | | but not in newer RTEMS. | ||||
* | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1997-08-28 | 1 | -3/+5 |
* | Reordered specs. | Joel Sherrill | 1997-07-10 | 1 | -4/+4 |
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 2 | -8/+36 |
| | | | | making sure every True/False reference was fully qualified. | ||||
* | Added RTEMS boolean constants. | Joel Sherrill | 1997-06-03 | 1 | -0/+3 |
* | Added Pending_Events and lined up other event constants | Joel Sherrill | 1997-06-03 | 1 | -33/+34 |
* | added more constants and fixed numer | Joel Sherrill | 1997-06-03 | 2 | -24/+64 |
* | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 1997-06-03 | 2 | -5/+74 |
* | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 1997-06-03 | 2 | -16/+6 |
| | | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | ||||
* | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1997-06-02 | 1 | -8/+23 |
* | added new files from test area. | Joel Sherrill | 1997-06-02 | 2 | -0/+3372 |
This code has successfully been used to run sp01. |
