2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Fix package name. | |||||
2002-10-29 | 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -1/+9 | |
* configure.ac: Remove AC_ENABLE_MULTILIB. * Makefile.am: Add CVS-Id. | |||||
2002-10-25 | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -3/+9 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-08-30 | 2002-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -11/+6 | |
* rtems.adb (IO_Initialize): Make this match the C prototype. | |||||
2002-08-27 | 2002-08-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+5 | |
* rtems.ads: Corrected binding for Io_Initialize. | |||||
2002-08-23 | 2001-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -0/+68 | |
* configure.ac: New. * Makefile.am: New. * .cvsignore: New. | |||||
2002-02-01 | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 5 | -294/+274 | |
* rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When. | |||||
2002-02-01 | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* ChangeLog: New file. | |||||
1999-10-21 | Added Semaphore_Flush. | Joel Sherrill | 2 | -0/+18 | |
1999-10-07 | Added Is_Suspended method. | Joel Sherrill | 2 | -0/+20 | |
1998-04-15 | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1 | -12/+13 | |
to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
1997-09-30 | fixed typo | Joel Sherrill | 1 | -1/+1 | |
1997-09-30 | Fixed typos. | Joel Sherrill | 1 | -1/+1 | |
1997-08-28 | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 2 | -64/+9 | |
but not in newer RTEMS. | |||||
1997-08-28 | Added IO_Error status code and fixed No_Memory error number. | Joel Sherrill | 1 | -3/+5 | |
1997-07-10 | Reordered specs. | Joel Sherrill | 1 | -4/+4 | |
1997-07-10 | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1 | -11/+10 | |
1997-06-03 | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 2 | -8/+36 | |
making sure every True/False reference was fully qualified. | |||||
1997-06-03 | Added RTEMS boolean constants. | Joel Sherrill | 1 | -0/+3 | |
1997-06-03 | Added Pending_Events and lined up other event constants | Joel Sherrill | 1 | -33/+34 | |
1997-06-03 | added more constants and fixed numer | Joel Sherrill | 2 | -24/+64 | |
1997-06-03 | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 2 | -5/+74 | |
1997-06-03 | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 2 | -16/+6 | |
shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | |||||
1997-06-02 | added Minimum_Stack_Size and Mode constants | Joel Sherrill | 1 | -8/+23 | |
1997-06-02 | added new files from test area. | Joel Sherrill | 2 | -0/+3372 | |
This code has successfully been used to run sp01. |
