path: root/cpukit/ada/rtems.ads (follow)
* 2003-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-251-0/+24
| | | | | PR 528/rtems_misc * rtems.ads: Add task variables to Ada binding.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | * rtems-multiprocessing.adb, rtems-multiprocessing.ads, rtems.adb, rtems.ads: URL for license changed.
* 2003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-031-2/+3
| | | | | | PR 338/filesystem * rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change).
* 2003-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-031-12/+16
| | | | | * rtems.ads: Corrected Configuration_Table record definition to match current RTEMS source. sp01 now runs.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-271-2/+1
| | | | * rtems.ads: Corrected binding for Io_Initialize.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-36/+50
| | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
* Added Semaphore_Flush.Joel Sherrill1999-10-211-0/+4
* Added Is_Suspended method.Joel Sherrill1999-10-071-0/+5
* Per suggestion from Eric Norum, went from one initial extension setJoel Sherrill1998-04-151-12/+13
| | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence.
* fixed typoJoel Sherrill1997-09-301-1/+1
* Fixed IO Manager calls to remove an argument which was used in 3.2.1Joel Sherrill1997-08-281-5/+0
| | | | but not in newer RTEMS.
* Added IO_Error status code and fixed No_Memory error number.Joel Sherrill1997-08-281-3/+5
* Reordered specs.Joel Sherrill1997-07-101-4/+4
* Added True and False constants for RTEMS.Boolean types. This necessitatedJoel Sherrill1997-06-031-0/+4
| | | | making sure every True/False reference was fully qualified.
* Added RTEMS boolean constants.Joel Sherrill1997-06-031-0/+3
* Added Pending_Events and lined up other event constantsJoel Sherrill1997-06-031-33/+34
* added more constants and fixed numerJoel Sherrill1997-06-031-8/+24
* added Signal constants, Is_Status_Successful, and Attribute constants.Joel Sherrill1997-06-031-5/+61
* added rtems_interrupt_level_attribute routien to return a properlyJoel Sherrill1997-06-031-5/+6
| | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK.
* added Minimum_Stack_Size and Mode constantsJoel Sherrill1997-06-021-8/+23
* added new files from test area.Joel Sherrill1997-06-021-0/+1336
This code has successfully been used to run sp01.
