* | 2002-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-30 | 1 | -11/+2 |
| | | | | * rtems.adb (IO_Initialize): Make this match the C prototype. | ||||
* | 2001-02-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-01 | 1 | -258/+150 |
| | | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When. | ||||
* | Added Semaphore_Flush. | Joel Sherrill | 1999-10-21 | 1 | -0/+14 |
* | Added Is_Suspended method. | Joel Sherrill | 1999-10-07 | 1 | -0/+15 |
* | Fixed typos. | Joel Sherrill | 1997-09-30 | 1 | -1/+1 |
* | Fixed IO Manager calls to remove an argument which was used in 3.2.1 | Joel Sherrill | 1997-08-28 | 1 | -59/+9 |
| | | | | but not in newer RTEMS. | ||||
* | fixed milliseconds and microseconds to tick conversion routines. | Joel Sherrill | 1997-07-10 | 1 | -11/+10 |
* | Added True and False constants for RTEMS.Boolean types. This necessitated | Joel Sherrill | 1997-06-03 | 1 | -8/+32 |
| | | | | making sure every True/False reference was fully qualified. | ||||
* | added more constants and fixed numer | Joel Sherrill | 1997-06-03 | 1 | -16/+40 |
* | added Signal constants, Is_Status_Successful, and Attribute constants. | Joel Sherrill | 1997-06-03 | 1 | -0/+13 |
* | added rtems_interrupt_level_attribute routien to return a properly | Joel Sherrill | 1997-06-03 | 1 | -11/+0 |
| | | | | shifted interrupt_level attribute field and RTEMS_INTERRUPT_MASK. | ||||
* | added new files from test area. | Joel Sherrill | 1997-06-02 | 1 | -0/+2036 |
This code has successfully been used to run sp01. |
