path: root/cpukit/ada/ChangeLog (follow)
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-111-0/+4
| | | | * Makefile.am: Use include_ada_HEADERS.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-301-0/+5
| | | | | * Makefile.am: Preinstall adainclude_HEADERS. Add $(dirstamp) to preinstallation rules.
* 2003-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-11-251-0/+5
| | | | | PR 528/rtems_misc * rtems.ads: Add task variables to Ada binding.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-0/+5
| | | | | * rtems-multiprocessing.adb, rtems-multiprocessing.ads, rtems.adb, rtems.ads: URL for license changed.
* 2003-07-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-07-081-0/+5
| | | | | PR 418/ada * rtems.adb: Add missing all keyword to derefence pointer.
* 2003-07-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-081-0/+6
| | | | | | * configure.ac: Remove (Merged into ../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../configure.ac.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-0/+4
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-0/+4
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-031-0/+6
| | | | | | PR 338/filesystem * rtems.adb, rtems.ads: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change).
* 2003-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-031-0/+5
| | | | | * rtems.ads: Corrected Configuration_Table record definition to match current RTEMS source. sp01 now runs.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-191-0/+4
| | | | * configure.ac: Fix package name.
* 2002-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-291-0/+5
| | | | | * configure.ac: Remove AC_ENABLE_MULTILIB. * Makefile.am: Add CVS-Id.
* 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-251-0/+4
| | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-211-0/+6
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-301-0/+4
| | | | * rtems.adb (IO_Initialize): Make this match the C prototype.
* 2002-08-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-271-0/+4
| | | | * rtems.ads: Corrected binding for Io_Initialize.
* 2001-08-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-231-0/+6
| | | | | | * configure.ac: New. * Makefile.am: New. * .cvsignore: New.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-0/+6
| | | | | | * rtems.ads, rtems.adb: Formatting cleaned up. Task based timer directives added. This is Timer_Initiate_Server, Timer_Server_Fire_After, and Timer_Server_Fire_When.
* 2001-02-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-011-0/+4
* ChangeLog: New file.
