* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING.
AC_PREREQ(2.62).
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/rtems-top.m4: Bump RTEMS_API to 4.8.
* aclocal/version.m4: Bump version to 4.7.99.0.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
* aclocal/rtems-top.m4: Rework rtems_updir handling to work around
ash cd'ing to '/' for 'cd .//'.
* aclocal/rtems-top.m4 (rtems_updir): Quote sed args.
* aclocal/prog-cc.m4: Remove refs to gcc-isystem.m4.
* aclocal/gcc-isystem.m4: Remove (Unused).
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V.
Remove CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE.
Cleanup comments.
* aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V.
* aclocal/prog-cc.m4: Remove RTEMS_USE_GCC.
* automake/compile.am: Cleanup comments. Remove ASFLAGS.
* aclocal/enable-itron.m4, aclocal/check-itron.m4:
Allow building itron for unix.
* aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac).
* configure.ac: Add RTEMS_CHECK_GCC_WEAK.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/version.m4: Updated to rtems-4.6.99.1.
* aclocal/rtems-cpu-subdirs.m4: Remove (Unused).
* configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]).
Add RTEMS_CHECK_SYSV_UNIX.
Add score/cpu/*/Makefile.
* score/cpu/Makefile.am: Add DIST_SUBDIRS.
* aclocal/rtems-top.m4: Don't AC_SUBST(PROJECT_ROOT).
Add project_libdir, project_include and libdir.
* aclocal/env-rtemscpu.m4: Remove all references to RTEMS_BSP.
Remove project_libdir, project_include and libdir.
Unconditionally use CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V.
* aclocal/rtems-top.m4: Add MULTISUBDIR. Add MULTIBUILDTOP.
Add rtems_updir. Remove version.m4 check.
Add PROJECT_ROOT/with_project_root processing.
Add PROJECT_INCLUDE. Add PROJECT_LIB.
* aclocal/env-rtemscpu.a4: Remove cpukit_topdir.
Remove with_project_root processing. Remove PROJECT_INCLUDE,
PROJECT_LIB.
* aclocal/version.m4: 4.6.99.0.
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* aclocal/version.m4: Updated to rtems-20031217-test.
* aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB.
* wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* aclocal/env-rtemscpu.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
* aclocal/lead-dot.m4: Remove (Use the version in automake-1.8).
* automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR).
* aclocal/env-rtemscpu.m4: Reflect new definition of project_lib.
* Makefile.am: Remove BUILT_SOURCES.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* aclocal/canonicalize-tools.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rtems-debug.m4,
aclocal/check-tool.m4, aclocal/enable-bare.m4,
aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/multi.m4,
aclocal/multilib.m4, aclocal/prog-cc.m4,
aclocal/rtems-top.m4, aclocal/sysv-ipc.m4:
Fix underquoting to silence automake-1.8.
