* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/enable-itron.m4, aclocal/check-itron.m4: Replace
RTEMS_HAS_ITRON_API with enable_itron.
* aclocal/enable-itron.m4: Cosmetics.
* aclocal/check-networking.m4: Do NOT disable networking for the
avr and the m32c.
Rework CFLAGS setup.
* aclocal/sysv-ipc.m4: Remove (unused).
* aclocal/check-networking.m4: Disable BSD TCP/IP for small memory
targets.
* aclocal/enable-itron.m4: Default to not building itron.
* aclocal/check-rtems-debug.m4: Add missing ','.
* libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS.
* aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack.
* rtems/include/rtems/rtems/types.h: Do not define rtems_boolean,
rtems_single, rtems_double unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
score/cpu/nios2/rtems/score/types.h: Removed.
* aclocal/prog-cc.m4: Add -Wnested-externs.
* aclocal/prog-cc.m4: Add -Wimplicit-function-declaration
-Wstrict-prototypes to RTEMS_CFLAGS.
* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING.
AC_PREREQ(2.62).
* aclocal/version.m4: Bump RTEMS_API to 4.9.
Bump RTEMS_VERSION to 4.8.99.0.
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/rtems-top.m4: Bump RTEMS_API to 4.8.
* aclocal/version.m4: Bump version to 4.7.99.0.
* ampolish3: New.
* aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3.
* aclocal/rtems-ampolish.m4: New.
* configure.ac: Use RTEMS_AMPOLISH3.
* aclocal/version.m4: Updated to rtems-4.6.99.3.
* aclocal/version.m4: Updated to rtems-4.6.99.2.
* aclocal/rtems-top.m4: Rework rtems_updir handling to work around
ash cd'ing to '/' for 'cd .//'.
* aclocal/rtems-top.m4 (rtems_updir): Quote sed args.
* aclocal/prog-cc.m4: Remove refs to gcc-isystem.m4.
* aclocal/gcc-isystem.m4: Remove (Unused).
* aclocal/rtems-flags.m4: Remove (Unused).
* aclocal/prog-ccas.m4: Remove $(GCCSPECS).
* aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V.
Remove CPU_CFLAGS.
* aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up
RTEMS_CFLAGS.
* automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS.
Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE.
Cleanup comments.
