path: root/cpukit/aclocal (follow)
* add --enable-paravirt in cpukit configure scriptsPhilipp Eppelt2013-11-271-0/+17
* add compare_and_swap check in check-atomic.m4WeiY2013-08-201-1/+3
* stdatomic.h support check when configureWeiY2013-07-171-4/+8
* configure: DocumentationSebastian Huber2013-06-122-2/+6
* smp: Add ARM supportSebastian Huber2013-05-311-1/+1
* smp: Add PowerPC supportSebastian Huber2013-05-311-1/+1
* New.Ralf Corsépius2013-02-141-0/+13
* cpukit/aclocal - Fix one mistake by scriptJoel Sherrill2012-05-111-0/+1
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1121-45/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0721-0/+49
* Remove CVS-Ids.Ralf Corsépius2012-05-0421-49/+0
* Revert "Google C++ Testing Framework 1.6.0."Sebastian Huber2012-01-262-47/+0
| | | | This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* Google C++ Testing Framework 1.6.0.Sebastian Huber2012-01-232-0/+47
* 2011-12-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-011-1/+1
| | | | * aclocal/check-smp.m4: Fix bogus log message.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-162-0/+37
| | | | | | | | | | | | | | | | | | | | | | PR 1729/cpukit * configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S, score/cpu/sparc/rtems/score/cpu.h, score/include/rtems/score/basedefs.h, score/include/rtems/score/context.h, score/include/rtems/score/percpu.h, score/src/percpu.c, score/src/thread.c, score/src/threadcreateidle.c: Add next step in SMP support. This adds an allocated array of the Per_CPU structures to support multiple cpus vs a single instance of the structure which is still used if SMP support is disabled. Configuration support is also added to explicitly enable or disable SMP. But SMP can only be enabled for the CPUs which will support it initially -- SPARC and i386. With the stub BSP support, a BSP can be run as a single core SMP system from an RTEMS data structure standpoint. * aclocal/check-smp.m4, aclocal/enable-smp.m4, score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h, score/src/smp.c, score/src/smplock.c: New files.
* 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-03-042-2/+2
| | | | | * aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API.
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-251-6/+9
| | | | | | | * aclocal/canonical-target-name.m4: Stop pretending no_cpu* was buildable. Derive RTEMS_CPU from "$host_cpu". Error out if "$host" doesn't match "*-*-rtems*".
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-252-4/+4
| | | | | * aclocal/check-networking.m4, aclocal/check-posix.m4: Rebase check on "$host".
* 2010-10-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-10-081-11/+10
| | | | | * aclocal/check-func.m4: Linearize checks. Add missing $2 to AC_CHECK_DECL.
* 2010-08-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-08-031-0/+24
| | | | * aclocal/check-func.m4: New.
* Remove.Ralf Corsepius2010-06-172-34/+0
* Remove.Ralf Corsepius2010-06-091-12/+0
* 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-06-071-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0.
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-292-4/+4
| | | | | * aclocal/enable-itron.m4, aclocal/check-itron.m4: Replace RTEMS_HAS_ITRON_API with enable_itron.
* 2010-04-29 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2010-04-291-2/+2
| | | | * aclocal/enable-itron.m4: Cosmetics.
* New.Ralf Corsepius2010-04-292-0/+24
* Add RTEMS_CHECK_GCC_PRINTF_LD_OFF_T, RTEMS_CHECK_GCC_PRINTF_LLD_OFF_T.Ralf Corsepius2010-04-131-0/+26
* 2009-11-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-11-191-3/+0
| | | | | * aclocal/check-networking.m4: Do NOT disable networking for the avr and the m32c.
* New.Ralf Corsepius2009-10-301-0/+88
* Remove RTEMS_CFLAGS.Ralf Corsepius2009-10-231-7/+5
| | | | Rework CFLAGS setup.
* 2009-10-14 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-141-125/+0
| | | | * aclocal/sysv-ipc.m4: Remove (unused).
* Remove unix/posix.Ralf Corsepius2009-10-144-27/+0
* 2009-08-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-171-0/+3
| | | | | * aclocal/check-networking.m4: Disable BSD TCP/IP for small memory targets.
* 2009-07-23 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2009-07-231-1/+1
| | | | * aclocal/enable-itron.m4: Default to not building itron.
* 2009-04-02 Ralf Corsépius <ralfcorsepius@rtems.org>Ralf Corsepius2009-04-021-1/+1
| | | | * aclocal/check-rtems-debug.m4: Add missing ','.
* Remove comment referring to HPUX.Ralf Corsepius2009-02-062-2/+0
* Remove tic4x.Ralf Corsepius2008-12-221-3/+0
* Use -r instead of -Wl,-r to build *.rels.Ralf Corsepius2008-12-101-1/+1
* 2008-12-08 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-12-081-0/+5
| | | | | * libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS. * aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack.
* 2008-09-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-09-221-2/+2
| | | | | * rtems/include/rtems/rtems/types.h: Do not define rtems_boolean, rtems_single, rtems_double unless RTEMS_DEPRECATED_TYPES is given.
* 2008-09-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-101-0/+3
| | | | | | | | | | | | | | | | | | | | * configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI C4x. Accidentally not done on 4.9 branch. :( * score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog, score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c, score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c, score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h, score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h, score/cpu/c4x/rtems/score/cpu_asm.h, score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h, score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog, score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c, score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c, score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h, score/cpu/nios2/rtems/score/cpu.h, score/cpu/nios2/rtems/score/cpu_asm.h, score/cpu/nios2/rtems/score/nios2.h, score/cpu/nios2/rtems/score/types.h: New files.
* 2008-09-10 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-101-3/+0
| | | | | | | | | | | | | | | | | | | | * configure.ac, aclocal/canonical-target-name.m4, score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch. * score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog, score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c, score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c, score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h, score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h, score/cpu/c4x/rtems/score/cpu_asm.h, score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h, score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog, score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c, score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c, score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h, score/cpu/nios2/rtems/score/cpu.h, score/cpu/nios2/rtems/score/cpu_asm.h, score/cpu/nios2/rtems/score/nios2.h, score/cpu/nios2/rtems/score/types.h: Removed.
* 2008-08-18 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2008-08-181-1/+1
| | | | * aclocal/prog-cc.m4: Add -Wnested-externs.
* 2008-08-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2008-08-161-2/+4
| | | | | * aclocal/prog-cc.m4: Add -Wimplicit-function-declaration -Wstrict-prototypes to RTEMS_CFLAGS.
* 2008-06-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-06-301-0/+4
| | | | | * aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62).
* 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2007-09-211-2/+2
| | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0.
* Upgrade to 4.7.99.2Joel Sherrill2007-08-071-1/+1
* Upgrade to 4.7.99.1Joel Sherrill2007-03-131-1/+1
* Revert to version 4.7.99-0Ralf Corsepius2007-02-221-1/+1
