closes #2443.
updates #2452.
Virtual machines with paravirtualization exist not only on x86.
for details.
This reverts commit 9bf3a868655f260c2fa6cbcab16f0218cf53e5b8.
* aclocal/check-smp.m4: Fix bogus log message.
PR 1729/cpukit
* configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S,
score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/context.h,
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/thread.c, score/src/threadcreateidle.c: Add next step in
SMP support. This adds an allocated array of the Per_CPU structures
to support multiple cpus vs a single instance of the structure which
is still used if SMP support is disabled. Configuration support is
also added to explicitly enable or disable SMP. But SMP can only be
enabled for the CPUs which will support it initially -- SPARC and
i386. With the stub BSP support, a BSP can be run as a single core
SMP system from an RTEMS data structure standpoint.
* aclocal/check-smp.m4, aclocal/enable-smp.m4,
score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h,
score/src/smp.c, score/src/smplock.c: New files.
* aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/canonical-target-name.m4:
Stop pretending no_cpu* was buildable.
Derive RTEMS_CPU from "$host_cpu".
Error out if "$host" doesn't match "*-*-rtems*".
* aclocal/check-networking.m4, aclocal/check-posix.m4:
Rebase check on "$host".
* aclocal/check-func.m4: Linearize checks.
Add missing $2 to AC_CHECK_DECL.
* aclocal/check-func.m4: New.
* aclocal/version.m4: Bump RTEMS_API to 4.11.
Bump _RTEMS_VERSION to 4.10.99.0.
* aclocal/enable-itron.m4, aclocal/check-itron.m4: Replace
RTEMS_HAS_ITRON_API with enable_itron.
* aclocal/enable-itron.m4: Cosmetics.
* aclocal/check-networking.m4: Do NOT disable networking for the
avr and the m32c.
Rework CFLAGS setup.
* aclocal/sysv-ipc.m4: Remove (unused).
* aclocal/check-networking.m4: Disable BSD TCP/IP for small memory
targets.
* aclocal/enable-itron.m4: Default to not building itron.
* aclocal/check-rtems-debug.m4: Add missing ','.
* libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS.
* aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack.
* rtems/include/rtems/rtems/types.h: Do not define rtems_boolean,
rtems_single, rtems_double unless RTEMS_DEPRECATED_TYPES is given.
* configure.ac, aclocal/canonical-target-name.m4: Readd NIOS2 and TI
C4x. Accidentally not done on 4.9 branch. :(
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: New files.
