* aclocal/version.m4: 4.6.99.0.
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* configure.ac, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4,
aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING
(deprecated in autoconf-2.59)
* automake/local.am: Remove clean-local, depend-gcc.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* aclocal/rtems-cpu-subdirs.m4: mips64orion port removed as mips port
more completely covers the MIPS family.
* aclocal/version.m4: Updated to rtems-20031217-test.
* aclocal/env-rtemscpu.m4: Remove stray '/' in PROJECT_LIB.
* wrapup/Makefile.am: Remove duplicate $(PROJECT_LIB) rule.
* aclocal/env-rtemscpu.m4: Add PROJECT_LIB.
* wrapup/Makefile.am: Use $(PROJECT_LIB) instead of ${PROJECT_RELEASE}/lib.
* aclocal/lead-dot.m4: Remove (Use the version in automake-1.8).
* automake/lib.am: Remove $(project_libdir)$(MULTISUBDIR).
* aclocal/env-rtemscpu.m4: Reflect new definition of project_lib.
* Makefile.am: Remove BUILT_SOURCES.
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* configure.ac: Use here-documents to generate cpuopts.tmp.
Various fixes and changes to argument processing.
Reflect changes to librpc Makefile.ams.
* acinclude.m4: Use here-documents to generate cpuopts.tmp.
* aclocal/check-itron.m4: Remove HAS_IRON_API.
* aclocal/check-multiprocessing.m4: Remove HAS_MP.
* aclocal/check-posix.m4: Remove HAS_POSIX_API.
* aclocal/canonicalize-tools.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rtems-debug.m4,
aclocal/check-tool.m4, aclocal/enable-bare.m4,
aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/multi.m4,
aclocal/multilib.m4, aclocal/prog-cc.m4,
aclocal/rtems-top.m4, aclocal/sysv-ipc.m4:
Fix underquoting to silence automake-1.8.
* configure.ac: Use RTEMS_INLINES instead of USE_INLINES.
Elimimate INLINESdir.
* aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS.
* .cvsignore: Add config.h.in.
* acinclude.m4: New.
* configure.ac: Don't use AUTOHEADER to generate cpuopts.h.
Add local autoheader config.h.
* aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST.
* aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* aclocal/check-posix.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/canonical-host.m4: Remove.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* aclocal/sysv-ipc.m4: Remove reference to RTEMS_CANONICAL_HOST.
* aclocal/canonical-target-name.m4: Use AC_CANONICAL_HOST instead of
AC_CANONICAL_TARGET. Use $host instead of $target.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Check for sys/cdefs.h.
* aclocal/env-rtems-cpu.m4: Add project_includedir.
Deprecate PROJECT_INCLUDE. Change project_includedir to
$(PROJECT_ROOT)/include for multilibs.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/rtems-debug.m4: Remove.
* aclocal/enable-rtems-debug.m4: New (Split out from rtems-debug.m4).
* aclocal/check-rtems-debug.m4: New (Split out from rtems-debug.m4).
* aclocal/version.m4: Updated to rtems-ss-20030703.
PR 321:
* aclocal/env-rtemscpu.m4: Remove support for profile-variant.
* automake/compile.am: Ditto.
* automake/local.am: Ditto.
* aclocal/env-rtemscpu.m4: Merge-in env-rtemsbsp.m4.
* aclocal/env-rtemsbsp.m4: Remove.
* aclocal/enable-rtemsbsp.m4: Remove.
2003-05-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* aclocal/env-rtemscpu.m4: Remove stray '/' in setting up
project_libdir.
* aclocal/version.m4: Updated to rtems-ss-20030417.
* aclocal/version.m4: Updated to rtems-ss-20030411.
* aclocal/version.m4: Updated to rtems-ss-20020411.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CHECK_CUSTOM_BSP.
* aclocal/check-bsps.m4: Remove.
* automake/multilib.am: Don't include @RTEMS_BSP@.cfg.
* automake/compile.am: Remove hard-coded CFLAGS_PROFILE_V.
Add autoconf-supplied CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V,
CFLAGS_PROFILE_V.
Hard-code RTEMS_CFLAGS_PROFILE = -pg
* aclocal/prog-cc.m4: Sync with toplevel/aclocal/prog-cc.m4.
Remove GCCSED.
* aclocal/env-rtemsbsp.m4: Add AC_ARG_VAR for CPU_CFLAGS,
CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V, CFLAGS_PROFILE_V.
* aclocal/rtems-flags.m4: New.
* aclocal/sysv-ipc.m4: Adaptation to autoconf-2.5x.
* aclocal/check-newlib.m4: Sync with ../aclocal/check-newlib.m4.
* aclocal/version.m4: Updated to rtems-ss-20021118.
* aclocal/prog-cc.m4: Acknowledge configuration-time CFLAGS.
* automake/compile.am: Acknowledge configuration-time CFLAGS.
Remove CFLAGS_DEFAULT.
* aclocal/version.m4: Updated to rtems-ss-20021111.
* aclocal/check-bsp-cache.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* aclocal/version.m4: Updated to rtems-20021021-test.
* aclocal/version.m4: Updated to rtems-JUNK.
* aclocal/version.m4: Updated to rtems-ss-20021004.
* aclocal/prog-gnat.m4: New.
* configure.ac: Add ada subdir handling.
* aclocal/bsp-alias.m4: Remove.
* setup.def, binutils/base-binutils.add, binutils/target-binutils.add:
Updated to binutils 2.13 which has no known issues.
* configure.ac: Add missing ',' to librpc activation.
Add AC_MSG_CHECKING/AC_MSG_RESULT.
* aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CONFIG_PER_BSP.
* aclocal/env-rtemscpu.m4: Remove RTEMS_CONFIG_PER_BSP.
Use AS_IF instead of if/then/else/fi.
