* | Upgrade to 4.9.34.9.3 | Joel Sherrill | 2009-11-13 | 1 | -1/+1 |
* | 2009-04-02 Ralf Corsépius <ralfcorsepius@rtems.org> | Ralf Corsepius | 2009-04-02 | 1 | -1/+1 |
| | | | | * aclocal/check-rtems-debug.m4: Add missing ','. | ||||
* | Upgrade to 4.9.2 | Joel Sherrill | 2009-03-12 | 1 | -1/+1 |
* | Upgrade to 4.9.1 | Joel Sherrill | 2008-12-12 | 1 | -1/+1 |
* | 2008-12-08 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-08 | 1 | -0/+5 |
| | | | | | * libfs/src/nfsclient/Makefile.am: Remove RTEMS_RELLDFLAGS. * aclocal/prog-cc.m4: Add RTEMS_RELLDFLAGS hack. | ||||
* | Upgrade to 4.9.0 | Joel Sherrill | 2008-09-24 | 1 | -1/+1 |
* | 2008-09-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-10 | 1 | -2/+0 |
| | | | | * aclocal/prog-cc.m4: Remove pre-production testing CFLAGS. | ||||
* | 2008-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-10 | 1 | -3/+0 |
| | | | | | * configure.ac, aclocal/canonical-target-name.m4, score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch. | ||||
* | 2008-08-18 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-18 | 1 | -1/+1 |
| | | | | * aclocal/prog-cc.m4: Add -Wnested-externs. | ||||
* | 2008-08-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-16 | 1 | -2/+4 |
| | | | | | * aclocal/prog-cc.m4: Add -Wimplicit-function-declaration -Wstrict-prototypes to RTEMS_CFLAGS. | ||||
* | 2008-06-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-06-30 | 1 | -0/+4 |
| | | | | | * aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING. AC_PREREQ(2.62). | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | Upgrade to 4.7.99.2 | Joel Sherrill | 2007-08-07 | 1 | -1/+1 |
* | Upgrade to 4.7.99.1 | Joel Sherrill | 2007-03-13 | 1 | -1/+1 |
* | Revert to version 4.7.99-0 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Use am_aux_dir/ampolish3. | Ralf Corsepius | 2006-12-13 | 1 | -1/+1 |
* | Remove RTEMS_AMPOLISH. | Ralf Corsepius | 2006-12-12 | 1 | -2/+0 |
* | Remove RTEMS_AMPOLISH. | Ralf Corsepius | 2006-12-12 | 1 | -0/+1 |
* | Integrate type checks. | Ralf Corsepius | 2006-11-18 | 1 | -11/+18 |
* | Integrate ITRON-type checks. | Ralf Corsepius | 2006-11-18 | 1 | -5/+11 |
* | Add RTEMS_AMPOLISH3. | Ralf Corsepius | 2006-11-15 | 1 | -0/+2 |
* | Pick up ampolish3 from ac_aux_dir. | Ralf Corsepius | 2006-11-15 | 1 | -1/+1 |
* | Remove. | Ralf Corsepius | 2006-10-21 | 2 | -56/+0 |
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 2 | -2/+2 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -1/+1 |
| | | | | * aclocal/rtems-top.m4: Bump RTEMS_API to 4.8. | ||||
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
* | Adaptations to automake-1.10. | Ralf Corsepius | 2006-10-16 | 3 | -9/+7 |
* | 2006-06-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-06-29 | 1 | -2/+3 |
| | | | | | * ampolish3: New. * aclocal/rtems-ampolish.m4: Reflect using in-sourcetree ampolish3. | ||||
* | 2006-05-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-05-16 | 1 | -0/+10 |
| | | | | | * aclocal/rtems-ampolish.m4: New. * configure.ac: Use RTEMS_AMPOLISH3. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | ||||
* | 2005-02-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-22 | 1 | -4/+4 |
| | | | | | * aclocal/rtems-top.m4: Rework rtems_updir handling to work around ash cd'ing to '/' for 'cd .//'. | ||||
* | 2005-02-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-08 | 1 | -1/+1 |
| | | | | * aclocal/rtems-top.m4 (rtems_updir): Quote sed args. | ||||
* | 2005-02-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-01 | 2 | -32/+1 |
| | | | | | * aclocal/prog-cc.m4: Remove refs to gcc-isystem.m4. * aclocal/gcc-isystem.m4: Remove (Unused). | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 1 | -11/+0 |
| | | | | * aclocal/rtems-flags.m4: Remove (Unused). | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 1 | -1/+1 |
| | | | | * aclocal/prog-ccas.m4: Remove $(GCCSPECS). | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -7/+1 |
| | | | | | | | | | | * aclocal/env-rtemscpu.m4: Remove CFLAGS_OPTIMIZE_V. Remove CPU_CFLAGS. * aclocal/prog-cc.m4: Don't invoke _RTEMS_FLAGS to set up RTEMS_CFLAGS. * automake/compile.am: AM_CFLAGS = RTEMS_CFLAGS. Remove CPPFLAGS, CFLAGS, CPU_CFLAGS, CFLAGS_OPTIMIZE. Cleanup comments. | ||||
* | 2005-01-05 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-05 | 2 | -4/+0 |
| | | | | | | * aclocal/env-rtemscpu.m4: Remove CFLAGS_DEBUG_V. * aclocal/prog-cc.m4: Remove RTEMS_USE_GCC. * automake/compile.am: Cleanup comments. Remove ASFLAGS. | ||||
* | 2004-11-22 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2004-11-22 | 2 | -29/+1 |
| | | | | | * aclocal/enable-itron.m4, aclocal/check-itron.m4: Allow building itron for unix. | ||||
* | 2004-09-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-21 | 1 | -0/+19 |
| | | | | | * aclocal/gcc-weak.m4: New (Extracted from cpukit/configure.ac). * configure.ac: Add RTEMS_CHECK_GCC_WEAK. | ||||
* | 2004-08-18 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-08-18 | 1 | -2/+2 |
| | | | | | PR 673/make_build * aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes. | ||||
* | 2004-07-28 | Joel Sherrill | 2004-07-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.1. | ||||
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 1 | -30/+0 |
| | | | | | | | | * aclocal/rtems-cpu-subdirs.m4: Remove (Unused). * configure.ac: Remove RTEMS_CPU_SUBDIRS([score/cpu]). Add RTEMS_CHECK_SYSV_UNIX. Add score/cpu/*/Makefile. * score/cpu/Makefile.am: Add DIST_SUBDIRS. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 2 | -31/+10 |
| | | | | | | | | * aclocal/rtems-top.m4: Don't AC_SUBST(PROJECT_ROOT). Add project_libdir, project_include and libdir. * aclocal/env-rtemscpu.m4: Remove all references to RTEMS_BSP. Remove project_libdir, project_include and libdir. Unconditionally use CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -53/+45 |
| | | | | | | | | | | * aclocal/rtems-top.m4: Add MULTISUBDIR. Add MULTIBUILDTOP. Add rtems_updir. Remove version.m4 check. Add PROJECT_ROOT/with_project_root processing. Add PROJECT_INCLUDE. Add PROJECT_LIB. * aclocal/env-rtemscpu.a4: Remove cpukit_topdir. Remove with_project_root processing. Remove PROJECT_INCLUDE, PROJECT_LIB. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: 4.6.99.0. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -25/+54 |
| | | | | | | | * aclocal/rtems-top.m4: Remove PROJECT_ROOT. Prepend ../ to $1. * aclocal/env-rtemscpu.m4: Reworked. * configure.ac: RTEMS_TOP([.]). | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 3 | -42/+4 |
| | | | | | | | | | | * aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT. Remove PROJECT_TOPdir (Unused). * aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE. Expand ${PROJECT_ROOT}. Remove RTEMS_ENABLE_BARE (Unused). Don't AC_SUBST RTEMS_BSP. * aclocal/enable-bare.m4: Remove (Unused). | ||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 1 | -7/+0 |
| | | | | | * aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4. Remove gnu-make endif HACK (Unused). |
