* | Upgrade to 4.11.99.0 | Sebastian Huber | 2015-09-11 | 1 | -2/+2 |
* | 2011-03-04 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-03-04 | 1 | -1/+1 |
| | | | | | * aclocal/rtems-top.m4, aclocal/version.m4: Rename RTEMS_API into _RTEMS_API. | ||||
* | 2010-06-07 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-06-07 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.11. Bump _RTEMS_VERSION to 4.10.99.0. | ||||
* | 2008-09-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-22 | 1 | -2/+2 |
| | | | | | * rtems/include/rtems/rtems/types.h: Do not define rtems_boolean, rtems_single, rtems_double unless RTEMS_DEPRECATED_TYPES is given. | ||||
* | 2007-09-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-09-21 | 1 | -2/+2 |
| | | | | | * aclocal/version.m4: Bump RTEMS_API to 4.9. Bump RTEMS_VERSION to 4.8.99.0. | ||||
* | Upgrade to 4.7.99.2 | Joel Sherrill | 2007-08-07 | 1 | -1/+1 |
* | Upgrade to 4.7.99.1 | Joel Sherrill | 2007-03-13 | 1 | -1/+1 |
* | Revert to version 4.7.99-0 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | Testing: Upgrade to 4.7.99.1 | Ralf Corsepius | 2007-02-22 | 1 | -1/+1 |
* | 2006-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-18 | 1 | -0/+2 |
| | | | | | * aclocal/rtems-top.m4: Remove RTEMS_API. * aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Bump version to 4.7.99.0. | ||||
* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | 2005-09-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-02 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.2. | ||||
* | 2004-07-28 | Joel Sherrill | 2004-07-28 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.1. | ||||
* | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-12 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: 4.6.99.0. | ||||
* | 2003-12-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-12-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-20031217-test. | ||||
* | 2003-07-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-07-03 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030703. | ||||
* | 2003-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-17 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030417. | ||||
* | 2003-04-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-04-11 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20030411. | ||||
| | | | | * aclocal/version.m4: Updated to rtems-ss-20020411. | ||||
* | missed in previous commit. | Joel Sherrill | 2003-02-07 | 1 | -1/+1 |
* | 2002-11-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-18 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021118. | ||||
* | 2002-11-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-11 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021111. | ||||
* | 2002-10-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-21 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-20021021-test. | ||||
* | 2002-10-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-04 | 1 | -1/+1 |
| | | | | * aclocal/version.m4: Updated to rtems-JUNK. | ||||
| | | | | * aclocal/version.m4: Updated to rtems-ss-20021004. | ||||
* | 2002-08-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-08 | 1 | -1/+1 |
| | | | | | * setup.def, binutils/base-binutils.add, binutils/target-binutils.add: Updated to binutils 2.13 which has no known issues. | ||||
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 1 | -0/+2 |
* copied over from aclocal/. |
