for details.
* aclocal/rtems-top.m4, aclocal/version.m4:
Rename RTEMS_API into _RTEMS_API.
* aclocal/rtems-top.m4: Require AC_DISABLE_OPTION_CHECKING.
AC_PREREQ(2.62).
* aclocal/rtems-top.m4: Remove RTEMS_API.
* aclocal/version.m4: Add RTEMS_API. Bump RTEMS_API to 4.8.
* aclocal/rtems-top.m4: Bump RTEMS_API to 4.8.
* aclocal/rtems-top.m4: Rework rtems_updir handling to work around
ash cd'ing to '/' for 'cd .//'.
* aclocal/rtems-top.m4 (rtems_updir): Quote sed args.
PR 673/make_build
* aclocal/rtems-top.m4 (RTEMS_TOP): Add further quotes.
* aclocal/rtems-top.m4: Don't AC_SUBST(PROJECT_ROOT).
Add project_libdir, project_include and libdir.
* aclocal/env-rtemscpu.m4: Remove all references to RTEMS_BSP.
Remove project_libdir, project_include and libdir.
Unconditionally use CPU_CFLAGS, CFLAGS_OPTIMIZE_V, CFLAGS_DEBUG_V.
* aclocal/rtems-top.m4: Add MULTISUBDIR. Add MULTIBUILDTOP.
Add rtems_updir. Remove version.m4 check.
Add PROJECT_ROOT/with_project_root processing.
Add PROJECT_INCLUDE. Add PROJECT_LIB.
* aclocal/env-rtemscpu.a4: Remove cpukit_topdir.
Remove with_project_root processing. Remove PROJECT_INCLUDE,
PROJECT_LIB.
* aclocal/rtems-top.m4: Remove PROJECT_ROOT.
Prepend ../ to $1.
* aclocal/env-rtemscpu.m4: Reworked.
* configure.ac: RTEMS_TOP([.]).
* aclocal/rtems-top.m4: Don't AC_SUBST PROJECT_ROOT.
Remove PROJECT_TOPdir (Unused).
* aclocal/env-rtemscpu.m4: Remove PROJECT_RELEASE.
Expand ${PROJECT_ROOT}.
Remove RTEMS_ENABLE_BARE (Unused).
Don't AC_SUBST RTEMS_BSP.
* aclocal/enable-bare.m4: Remove (Unused).
* aclocal/rtems-top.m4: Remove check for cpukit/aclocal/version.m4.
Remove gnu-make endif HACK (Unused).
* aclocal/lead-dot.m4: New (from automake-1.7f).
* aclocal/rtems-top.m4: Require AM_SET_LEADING_DOT.
Add AC_SUBST(dirstamp).
* aclocal/canonicalize-tools.m4, aclocal/check-itron.m4,
aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rtems-debug.m4,
aclocal/check-tool.m4, aclocal/enable-bare.m4,
aclocal/enable-inlines.m4, aclocal/enable-itron.m4,
aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4,
aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4,
aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4,
aclocal/gcc-pipe.m4, aclocal/multi.m4,
aclocal/multilib.m4, aclocal/prog-cc.m4,
aclocal/rtems-top.m4, aclocal/sysv-ipc.m4:
Fix underquoting to silence automake-1.8.
* aclocal/rtems-top.m4: Add RTEMS_API.
AC_DEFAULT_PREFIX([/opt/rtems-][RTEMS_API]).
* aclocal/rtems-top.m4: Use with_project_root and MULTIBUILDTOP to
compose PROJECT_TOPdir (Fixes hppa1.1/genoffset problem).
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
$(PROJECT_RELEASE)/lib.
* aclocal/rtems-top.m4: Reflect relocation of c/src/exec to cpukit.
* aclocal/check-cpu.m4: Ditto.
* aclocal/check-bsps.m4: Ditto.
* automake/multilib.am: Add install-multi.
* aclocal/rtems-top.m4: Reflect new RTEMS_TOPdir to detecting
version.m4.
Add --with-project-root.
Reflect --with-project-root to setting up PROJECT_ROOT.
* aclocal/env-rtemscpu.m4: Reflect new RTEMS_TOPdir (HACK).
* aclocal/check-cpu.m4: Reflect new RTEMS_TOPdir.
* aclocal/check-bsps.m4: Reflect new RTEMS_TOPdir.
* copied over from aclocal/.
