2021-11-29 | */aclocal/*: Remove remnants of autoconf/automae build system | Joel Sherrill | 1 | -17/+0 | |
Updates #4081. | |||||
2018-06-28 | build: Enable RISC-V SMP build | Sebastian Huber | 1 | -1/+1 | |
Update #3433. | |||||
2013-06-12 | configure: Documentation | Sebastian Huber | 1 | -1/+2 | |
2013-05-31 | smp: Add ARM support | Sebastian Huber | 1 | -1/+1 | |
2013-05-31 | smp: Add PowerPC support | Sebastian Huber | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2012-05-07 | Revert: Remove CVS Ids | Joel Sherrill | 1 | -0/+2 | |
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | |||||
2012-05-04 | Remove CVS-Ids. | Ralf Corsépius | 1 | -2/+0 | |
2011-03-16 | 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com> | Joel Sherrill | 1 | -0/+18 | |
PR 1729/cpukit * configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S, score/cpu/sparc/rtems/score/cpu.h, score/include/rtems/score/basedefs.h, score/include/rtems/score/context.h, score/include/rtems/score/percpu.h, score/src/percpu.c, score/src/thread.c, score/src/threadcreateidle.c: Add next step in SMP support. This adds an allocated array of the Per_CPU structures to support multiple cpus vs a single instance of the structure which is still used if SMP support is disabled. Configuration support is also added to explicitly enable or disable SMP. But SMP can only be enabled for the CPUs which will support it initially -- SPARC and i386. With the stub BSP support, a BSP can be run as a single core SMP system from an RTEMS data structure standpoint. * aclocal/check-smp.m4, aclocal/enable-smp.m4, score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h, score/src/smp.c, score/src/smplock.c: New files. |
