path: root/cpukit/aclocal/enable-inlines.m4 (follow)
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-111-1/+1
| | | | | | | | | | * configure.ac, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/multi.m4, aclocal/multilib.m4: Use AS_HELP_STRING instead of AC_HELP_STRING (deprecated in autoconf-2.59) * automake/local.am: Remove clean-local, depend-gcc.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-1/+1
| | | | | | | | | | | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8.
* 2003-11-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-241-11/+4
| | | | | | | * configure.ac: Use RTEMS_INLINES instead of USE_INLINES. Elimimate INLINESdir. * aclocal/enable-inlines.m4: Ditto. Remove RTEMS_USE_MACROS. * .cvsignore: Add config.h.in.
* 2003-11-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-201-5/+2
| | | | | | | | * acinclude.m4: New. * configure.ac: Don't use AUTOHEADER to generate cpuopts.h. Add local autoheader config.h. * aclocal/canonical-target-name.m4: Require AC_CANONICAL_HOST. * aclocal/enable-inlines.m4: Remove USE_MACROS (Unused).
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-171-0/+21
* copied over from aclocal/.
