2003-11-26 | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -1/+1 | |
* aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8. | |||||
2002-06-17 | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+0 | |
* copied over from aclocal/. | |||||
2002-01-08 | 2002-02-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -3/+4 | |
* aclocal/check-tool.m4: Remove AC_CHECK_TOOL_PREFIX, conditionalize check upon host_alias != build_alias. | |||||
2000-11-03 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+10 | |
* aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro. |
