path: root/cpukit/aclocal/check-rtems-debug.m4 (follow)
* 2009-04-02 Ralf Corsépius <ralfcorsepius@rtems.org>Ralf Corsepius2009-04-021-1/+1
| | | | * aclocal/check-rtems-debug.m4: Add missing ','.
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-261-1/+1
| | | | | | | | | | | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-itron.m4, aclocal/check-multiprocessing.m4, aclocal/check-newlib.m4, aclocal/check-posix.m4, aclocal/check-rtems-debug.m4, aclocal/check-tool.m4, aclocal/enable-bare.m4, aclocal/enable-inlines.m4, aclocal/enable-itron.m4, aclocal/enable-multiprocessing.m4, aclocal/enable-networking.m4, aclocal/enable-posix.m4, aclocal/enable-rtems-debug.m4, aclocal/env-rtemscpu.m4, aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4, aclocal/multi.m4, aclocal/multilib.m4, aclocal/prog-cc.m4, aclocal/rtems-top.m4, aclocal/sysv-ipc.m4: Fix underquoting to silence automake-1.8.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-0/+7
* aclocal/rtems-debug.m4: Remove. * aclocal/enable-rtems-debug.m4: New (Split out from rtems-debug.m4). * aclocal/check-rtems-debug.m4: New (Split out from rtems-debug.m4).
