* aclocal/check-networking.m4, aclocal/check-posix.m4:
Rebase check on "$host".
* aclocal/check-networking.m4: Do NOT disable networking for the
avr and the m32c.
* aclocal/check-networking.m4: Disable BSD TCP/IP for small memory
targets.
* aclocal/enable-networking.m4: Don't AC_SUBST(RTEMS_HAS_NETWORKING).
* aclocal/check-networking.m4: Don't AC_SUBST(HAS_NETWORKING).
* automake/amcompile.am: Remove $(ARCH).
* wrapup/Makefile.am: Add $(ARCH).
Remove compile.am, lib.am.
Include amcompile.am.
* aclocal/check-multiprocessing.m4: Add m4-quotes.
Remove RTEMS_CHECK_CPU.
* aclocal/check-itron.m4: Add m4-quotes.
Require RTEMS_CANONICAL_TARGET_CPU instead of RTEMS_CHECK_CPU.
* aclocal/check-networking.m4: Add m4-quotes.
* aclocal/check-cpu.m4: Remove.
* aclocal/canonical-target-name.m4: Add m4-quotes.
* configure.ac: Merge-in former aclocal/check-cpu.m4.
* configure.ac: Add missing ',' to librpc activation.
Add AC_MSG_CHECKING/AC_MSG_RESULT.
* aclocal/check-networking.m4: Let AC_MSG_CHECKING refer to CPU.
* copied over from aclocal/.
